RV.Net Open Roads Forum: Toy Haulers: New tire upgrade
Search only in Toy Haulers
 > New tire upgrade
bbsplash
Kearney, Missouri
Posted: 07/08/08 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking to replace my Raptor tires. I'm going to replace my st225-75-15 with 16" Michelin Ribs.
Those of you that have replaced your tires, What size Michelin's did you upgrade to?
Thanks, Todd
shooters
Southern Calif
Posted: 07/08/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
How old is your Raptor; how mnay miles on your exisiting tires?
lincster
Mesa Az
Posted: 07/08/08 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I went with 225/75/16 but only cause I didn't have the clearance on my first trailer.
If I had the room, I would do the 235/86/16. They have the highest load rating.
Good call on changing to those tires.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Aaron H
Mesa, AZ
Posted: 07/08/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I think mine are 235/85 (not 86).
2003 Honda CR80B
2004 Suzuki Z400 Limited Ed.
2005 Yamaha YFZ450
2006 Yamaha Raptor 700LE
2006 LE3305 Weekend Warrior
2008 GMC 3500DRW
2008 Harley Heritage
Madhatter1
Madeira Beach FL
Posted: 07/08/08 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 08 Fuzion 373 (Raptor twin) that came with the 07 15" rims, I put Denman load range E 15" on. We just towed over 5500 miles with no issues. Tires got warm, not hot. I was tempted to go to 16", but I like the factory look. Remember to check axle alignment if you are having any issues. I drive 65 to 68 max. Good luck.
JIMNLIN
Big Cabin, OK
Posted: 07/08/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I went with 215/85-16 E for clearence issues on my 11200 GVWR 5er
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
lincster
Mesa Az
Posted: 07/08/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
WHOOPS!!!!
bbsplash
Kearney, Missouri
Posted: 07/08/08 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
The tires are on an 08 raptor, they only have about 8000-9000 mi. on them. One tire has a blister about 1/2 in. x2 in. on the side wall. Two others have areas on the side wall that just doesn't look right.I keep these tires aired up at 65 psi and check before this rig rolls.The tires just look "squishy" Keystone should have put "e" rated tires on this thing, 15 in "d" doesn't seem heavy enough for me, imo.
 > New tire upgrade
