paedbo
ct
Hi guys, I need to modify the plumbing in my TT so i can move the fresh water tank, I been doing searches and at first thought maybe i have pex?? but now im unsure, Below is a picture you can see the hose on the bottom right can someone tell me what that is and where i could get fittings for it?
Water Tubing
Thanks
Polishnurse
Schodack, NY
If you talking about the gray tubing with the metal clamps it looks like PEX to me. Bill
PA14Jim
Sterling, Alaska
If it is the grey looking pipe laying on the yellow floor, it looks like CPVC, if so, Home Depot or Lowes. jim
Jim
02 Travelaire Gensis
03 GMC Duramax
wolfcat1
near Beaumont, Texas
it is a type of pex. cpvc is a yellowish gold color and all joints are glued
paedbo
ct
ok guys, yes it is grey with what looks like aluminum or steel crimped bands on it. it is very flexible i can almost bend the hose back on itself. I guess i would try a sharkbite fittings?
edit- sorry i just realized one of the steel braided lines for the water heater is also showing in the pic, Yes i mean the one that has the 90 elbow with the fittings.
Housted
Los Angeles, CA
It is a type of PEX called Quest, unless you want to buy a crimper and the bands necessary, I would use fittings called Flair-It. They are very easy to use and will do the job well. Most big RV stores have them in the service department. The size is 1/2".
Housted
2007 Dodge 2500 5.9 CTD Tow Rig
2006 Arctic Fox 29V TT
Too many mods to Truck and trailer to list.
Pictures
woodylake
C'villle Va
Looks like Quest to me. Was your trailer Built before 1990? You can still convert to pex easily. Lowes or home depot has all the parts.
Quest is gray and pex is clear or white or colored red for hot and blue for cold
2002 Z71 Tahoe
2003 Sunline 2553
Kayaks,Bikes and Golf
50 Plus ain't so bad!
Rumtan
Alberta
Qwest was used up until 1998 on just about all TTs....now they use the white lines which is pex....no the two lines arent the same size and hence none of the fittings work either.
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
paedbo
ct
Thanks guys, yes it was built in 1986, is the quest bad? I dont see anything wrong with any of it , I just wanted to move the fresh water tank closer to the axles since it was right at the front of the trailer. Filling it did a number on tongue weight.
So now im a bit confused rumtan, the flair-it fittings wont work? Is that what you mean?
edited 07/08/08 07:00pm by paedbo *
fatmanobx
kill devil hills, n.c.
I deal with quest every day and it got to be the biggest screwup that ever came down the line. It gets pin holes, cracks at joints, coupling retaining rings cut into the pipe causing leaks. It crap. It has been outlawed for the use in residential and commercial use. The company that use to make it made a half hearted settlement to folks who got stuck with it. Replace with pex and you will have no problems. Good luck..
2003 Four Winds Infinity 37'
