RV.Net Open Roads Forum: Travel Trailers: type of plumbing in tt?
 > type of plumbing in tt?
paedbo
ct
Posted: 07/20/08 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys , I will convert it to pex. But for now I will do all the open areas up front going to water heater etc and then adapt it to the quest. Then just before winter I'll start digging out the quest in the back of the trailer and have it fully converted.
LAdams
Northern Illinois
Posted: 07/20/08 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
LarryJM wrote:
Problem is that it's near impossible to get those crimpers into a lot of the confined spaces in most RVs like under the sinks and around the water pump.
Aw come on Larry - I don't agree with that at all - have you ever even tried it yourself or are you just making a comment of what you THINK it might be???
The head of the compound crimper is pretty small and I have gotten it into some extremely tight confines...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
LarryJM
NoVa
Posted: 07/21/08 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Les
Yes, I have. When I redid my low point drains I actually bought the PEX tool and couldn't get it on the lines inside the enclosed underbelly w/o removing the underbelly completely since the factory drains are just forward of the axle and the underbelly is one continuous piece. Also, to remove the underbelly I would have to remove all the LP gas lines that run outside the underbelly. Also, I couldn't get the tool to fit over 1/2 the PEX connections just around my WP compartment below with the jaws opened. There might be some pricey PEX crimpers that would work, but IMHO it's still iffy in some of these really confined spaces.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974. TRAILER MODS
