RV.Net Open Roads Forum: Beginning RVing: What you need to get started
 > What you need to get started
Pucka1378
Posted: 07/08/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
So I have been reading and I have been learning.
So I know that I need for a TT or I think I need LOL
Brake controller
Hitch
Sway control
I am trying to come up with some sort of budget on these "extras" that I never thought about before LOL
Also I have seen on here about the sleep number beds for the RV. Can you use one from your home? We have one and we are maybe on planning on living in a TT for 3-6 months so I am thinking I can just put in the one we already own.
Thanks!
lat471
Lebanon, PA
Posted: 07/09/08 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Make a bigger budget there are always extras.
07 Cameo LXI F35FD3
R Taj-We-Haul
retiredtraveler
Woodstock Il --- GO HIKING!!!!
Posted: 07/09/08 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Yes, assume you're going to spend thousands (yes, thousands) for "extras" which are really not extra, but required for safe travel. The controller, hitch, and sway are the major items.
Also, are you set to tow? You will need a tranny cooler, if you're driving an automatic. You may need something in the way of levelers and chocks depending on what comes with the trailer.
That covers most of the travel/safety items. Then it comes down to how much camping gear you want (or don't want). Those are purely optional. For instance, do you want an outdoor grill, or a 'camp kitchen' of some type. Add-a-room? Do you have all the kitchen items you need to stock the trailer? Hoses and connectors to clean out blackwater?
I would advise that you only purchase, at this time, the basic items to safely function. Camp for a season and see what other camping-related items you find yourself wanting, or needing, instead of rushing to buy lots of shiny new toys.
Pup: 2007 Jayco 1206 w/slide-out + shower
surge brakes, 54w solar panel
TV: 2005 Nissan Xterra 4X4, manual trans
25 years tent camping, 4000+ miles of hiking, lots of biking
Warfire80
Round Lake Beach, IL
Posted: 07/09/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Depending on you TV you may already have a tranny cooler installed, if it came from the factory with a tow pkg on it then most likely you have a tranny cooler. We just bought a new TT and it did not come with leveling jacks, the dealer wants like $400 for them installed, so i looked on the internet and you can get BAL 24" 5000lbs rated jacks for around $150 shipped. But our list of items to buy keeps growing for some odd reason, but will take it in stride and I am sure in a a couple years we will have everything.
Hornet28BHDS
Parker, PA
Posted: 07/09/08 10:21am Link  |  Quote  |  Print  |  Notify Moderator
That's definately something you need to know!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Pucka1378
Posted: 07/09/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
WE have been tent camping for years so we have all of the camping stuff for that. That will be put into a TT(pots, pans, dishes etc)
We do have a truck that came with the towing package from the factory.
Pucka1378
Posted: 07/09/08 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Last night there were a couple other responses on here what happened to them?
Pucka1378
Posted: 07/09/08 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Never mind it looks like it double posted. So I found the other thread.
Wildwood TT
Posted: 07/09/08 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Pucka1378-
We also are moving up from tents to a TT...should be delivered here on Monday. We don't even have possession of our TT yet but I will tell you a few things we have begun to gather so we can spread out the expense of fitting out our rig. Those veteran rver's should feel free to correct me if I should mention anything you don't agree with. The obvious and $$$ towing necessities have already been mentioned but you will need some less expensive items that are also very necessary. First of all, get a good 20ft. sewer hose. CW has a Deluxe Bayonet Sewer Kit that includes pre-assembled hose and sewer fitting for $44.99 but you will also need to get a clear view 90 degree sewer adapter w/lugs ($11.10)to attach to the sewer hose. The reason you need this is bc it will allow you to see when all the dark water has been dumped. Pick up a rubber sewer doughnut (aka sewer seal) for$4.44 while you are there too. You may not need it at all campgrounds but it's better to have one than to wish you had one when you need it. You can search recommended toilet chemicals on this forum and get all sorts of good advice for that but buy them at Walmart along with the tp cause it will be cheaper than CW.
Wildwood TT
Posted: 07/09/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
Continued...get some good tire chocks; not the cheap, plastic ones for less than $3. I have heard some bad stories. CW has tire lock chocks made by BAL model #28000A that run $36.66...not cheap but these were recommended to me by someone who has rv'd with the same pair of chocks for over 30 years. Safety and reliability are worth the price. Depending on the size of your TT, you will either need 2 or 4 chocks. Get a drinking water hose...not the garden type bc the garden type has chemicals that build up and are not safe for drinking out of. CW has a "Never Kink" 25ft. for $13.88. Also pick up a "Hi Flow" water regulator($11.66) and a hose protector ($6.66).
