RV.Net Open Roads Forum: Toy Haulers: WW 3505 15" to 16" Upgrade?
Search only in Toy Haulers
 > WW 3505 15" to 16" Upgrade?
Racorman
Santa Cruz, California
Posted: 07/10/08 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
rdam wrote:
Ok. I've got the old fashioned hangers, and new hangers/blocks/rims/tires is just not $$$ possible right now.
So the next question is, are the stock 15" rims capable of, or rated for the pressure of an "E" rated/10 Ply 15" tire (80 PSI)? I could get Maxxis tires in "E" rating which would represent a substantial upgrade. It's not a Michelin XPS, but I've got to work with what I've got.
I don't remember if those stock WW wheels are rated to 80 PSI. I think it is stamped on the inside the rim, so the tire has to come off to see what it's rated to. Someone had previously posted about that.
AKA..... 56Nomad
2006 Weekend Warrior (LE3305)
1999 Lance Camper (1130)
2005 King Quad 700
2008 King Quad 750
Haul all the toys with a Chevy 1 Ton Duramax/Allison 4x4 -Edge w/Juice and 4" Exhaust
lincster
Mesa Az
Posted: 07/11/08 07:22am Link  |  Quote  |  Print  |  Notify Moderator
The inside of my stock wheels from my 06 Warrior says 65psi max.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Racorman
Posted: 07/11/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Thanks lincster....... I knew there was a reason I had to put new
D rated 15"tires on my stock wheels
rdam
Lake City, Florida
Posted: 07/13/08 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Everywhere a roadblock!!!! I'll pull one and check. I actually spoke to a "tech" at WW (Yup, they answered the phone) who said the "E"'s should be fine at 80 PSI. But I guess I'll have to look at the rim/wheel and confirm. Thanks everybody for your help.
2006 Weekend Warrior LE 3505
2004 Ford F-250 Supercab 6.0L Diesel/Auto
Racorman
Posted: 07/13/08 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
Inquiring minds need to know..... please keep us posted.
rdam
Lake City, Florida
Posted: 08/11/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Still contemplating the tire situation. It appears that some of the steel wheels are rated by weight. And some of the aluminum wheels are rated by PSI. I find it hard to believe that my 15" steel WW wheels are rated at 65PSI max, and that is the recommended pressure, which could easily be exceeded as soon as the tire heats up.
I did come across this ad at http://store.weekendwarriorgear.com/wewatrtiandc.html
"ST 225/75R15 Weekend Warrior Trailer Tires and Chrome rims for sale. They are brand new out of the factory. The rims are 6 lug and the tires are Load Range E and made for trailers. Pick-up is available in Southern California."
These are the same wheels I have, and the tires shown are "E" rated Transmasters. Anybody running these? Or can confirm that these were a WW factory option?
JFJ
TN
Posted: 08/11/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
This afternoon I bought Michelin LTX 225 75R 16 Load Range E for $136 tire and 16 inch Greenball Wheels (almost exactly what was on my Raptor and like the one in the pic above) 6 on 5.5 bolt pattern for $85 a wheel. Got 'em from Discount Tire. Great service. The rim is rated at 3200 lbs. The tire is rated at 2680 lbs. I bought 7 for my Raptor (6 plus the spare). This was an upgrade from a 15 setup. I looked for almost 2 weeks long and hard. This was what I came up with after doing the homework. The XPS Rib is a great tire, as well.
2007 Dodge Megacab 2500 4X4 SRW
6.7 Cummins w/6 Speed Auto
2005 Raptor 3612ds
Pacbrake Air Bags
Prodigy Brake Controller
Pullrite Superglide 24K
rdam
Lake City, Florida
Posted: 09/14/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I've pulled a rim and there is NO rating information inside the rim or on the exterior inner or outer surface. NO PSI, and NO maximum load. Several tire stores have said that if the "E" rated 15" Maxxis tire requires a 15x6 rim (which is what they are), then I should be fine.
So, I am ordering (7) Maxxis 225/75/R15 "E"'s and mount them to the original rims.
high desert
Verdi, Nevada
Posted: 09/14/08 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
I was told by WW that my original '06 wheels were not rated to handle the 80 psi necessary for E rated tires. I did the block lift and went with 16" E rated xps ribs.
I would not put 80 psi on stock '06 WW 15" wheels.
06 Silverado 3500 CC DRW 4x4 LT3 D/A
06 Weekend Warrior FSC2800, billet
Putnam XDR/Hensley Arrow
BrakeSmart
08 Polaris Outlaw 525 KTM IRS
08 Honda TRX 400 EX
08 Polaris Scrambler 500 4x4
2 Honda Foreman 4x4
Honda Sportrax 250 EX
Honda Sportrax 90
rdam
Lake City, Florida
Posted: 09/14/08 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting. WW told me the "E"'s with 80 PSI should be fine (see earlier post). Are your's 15"x6", and are they 6 lug?
