RV.Net Open Roads Forum: Beginning RVing: power cable
 > power cable
Rolo2
Baldwin, NY
Posted: 07/09/08 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
I want to connect the electric to my house, Can you tell me where I can buy a 30 amp power cable for a decent price? Thanks.
Polishnurse
Schodack, NY
Posted: 07/09/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Wallmarts, just buy the 30 amp extension cord and cut of the female end and presto, you have a power cord that you can now terminate in your existing pannel. Bill
Kirk
Livingston, Texas.
Posted: 07/09/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
I suggest that you not use a power cord but buy the proper cable from Home Depot or Lowe's or from some other building supply company. I assume that you plan to install a 30A outlet for your RV. Install a circuit breaker in the distribution box and then use proper electrical cable. I would also put a means of turning off power to the outlet in the box with the outlet, just for safety in an emergency in the RV. You can purchase all of the parts that you need at either of the stores mentioned.
Good travelin! ........Kirk
sent via Starband, Manual Flyer dish
www.adventure.1tree.net
John3872
Iowa
Posted: 07/09/08 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Are you just looking to buy a 30 Amp adapter plug? Wal-Mart has them fairly inexpensive.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
Wherever I happen to park
Posted: 07/09/08 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
I will second the recommendation of Kirk.. Get the proper cable from Lowes or Home Depot. The proper outlet in the proper kind of box (You may be able to find that at Lowes/Home depot too. else try an RVstore) and a 30 amp SINGLE breaker
Do it right.
IF you run the cable under ground get UF cable (Underground Feeder) more expensive but .. Worth it
Nick Wildwood
Hell California
Posted: 07/09/08 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
First off you have to have a 30 amp circuit to plug it into. You will need a home run from your house panel to a receptacle box which you should mount close enough to the RV so you don't need an extension cord. Get a cover which has the large enclosure so that it can close with the cord plugged in. For a 110 volt, 30 amp circuit, you will need black number 10 wire, white number 10 wire and green number 10 or 12. (Check your local electric code.) While you are at it you might as well install a 20 amp circuit next to it for your other electrical needs. Just run another set of number 12 wire for it in the same conduit. Used EMT above ground and PVC underground and up to the EMT. Direct burial wire is for garden lighting and is a pain in the butt to strip. Do it right and it will increase the value of your home.
tvman44
Southwest Louisiana
Posted: 07/10/08 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Get a 30 amp extension cord from Walmart and cut off the female end off if not needed.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
 > power cable
