saggys
WI
Finally built my hitch extension. Started out with a Ford V5 hitch rated at 5000lb tow and 500lb tongue, weight carrying. Added another 8" reciever tube with 4-1/4" by 1.5" straps. Then 100% welded all seems and also added corner gussets at cross tube and frame mounts. Also added 1/4" angle from lower receiver tube to cross tubes to stiffen. For the reciever I used 2-18" 2 inch solid square stock and 2-18" reciever tubes so I had 6" overlap on both ends making the receiver 24" long, it is joined together with 4- 3/16" straps and weighs 60lbs +. I have chains and turnbuckles attaching it to the frame mounts. The lowest safe work limit is on the turnbuckles at 1,800lbs each. All welds were done with a 6011 root and 7018 follow up with a DC stick welder.I modeled it after another popular double truss hitch. Now I can still use my torque lift tie downs with my stock receiver. The load in question has 230lbs tongue weight and weighs about 3,000lbs. Now I need to post pic's,I will try to figure it out. Initial tow test seems fine.
1999 F350 4WD CC SRW V-10, 4.30 Tow Package,HD Camper Package,Rancho,Firestone Bags,Vision 81's,BS M729 tires.
2003 Lance 1010,Torque Lift tie downs with Fastguns.
1999 Warrior 2090BT
SoCalDesertRider
SanDiego, CA, USA
Sounds great! Post some pics for us to see!
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
BradW
Flat Rock, Alabama
Well, not worthless, but photos would definately help.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
Crumm
Fairbanks Alaska
Hard to tell from your description but it sounds like you added a ton of iron to a V5 hitch cross tube. The cross tube is the first thing to fail in most receiver hitch failures. Sounds like you did add gussets to the cross tube so it might be tough. Putting 230# on the end of a 24" receiver extension is way more stress than a hitch cross tube designed to carry 500# of tongue weight can handle. A picture would probably show your design better than a description. The double truss sounds like it is plenty stout but if the tube that connects it to the frame breaks the truss will be in the ditch with the trailer. A hitch extension is only as strong as the weakest link.
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS with leg extensions
06' Jetcraft XS.
94' Wells Cargo 7'x14'
Slide-Show
Too_Tall_Ford
Reno, NV
I am looking forward to seeing your pics. I want to build my own extension for flat towing my Jeep.
2000 F350 DRW 4wd CC 7.3l PSD
37" Tires w/ 5.13's
Suncoast 4R100
2007 Host Yellowstone
Democracy is 2 foxes and a sheep deciding on what to have for lunch, liberty is a well armed sheep contesting the vote.
Matthew_B
The boonies near Dallas, Oregon
Too_Tall_Ford wrote: I am looking forward to seeing your pics. I want to build my own extension for flat towing my Jeep.
I did my own design. Details Here
PM me if you want plans for it.
saggys
WI
Here's a pic
last
edited 07/11/08 08:52am by an administrator/moderator *
View edit history
saggys
WI
another pic
last
edited 07/11/08 08:48am by an administrator/moderator *
View edit history
saggys
WI
yet another pic
edited 07/11/08 04:31pm by an administrator/moderator *
saggys
WI
