RV.Net Open Roads Forum: Tech Issues: Frost on Fridge Cooling Fans
 > Frost on Fridge Cooling Fans
KEBrown
Kansas
Posted: 07/10/08 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Brand new Norcold 641 fridge. Setting 6 out of 9; Frost on cooling fins in fridge; not a solid block of ice but there is frost on it. It has food in it but it's not packed completely full, enough for the weekend. Is this normal, how much is normal? Inside temp is 37 degrees and I do have a one of those little blue DD fans on the bottom shelf. The manual says it periodically heats the fins to defrost the, other wise I have to empty it and defrost it; it's only been on about 30 hours, from 11PM last night to 7AM this AM it hasn't changed any, still frosted. I don't remember my old Dometic doing that. I heard Norcold was 'spose to be better than Dometic, but I've found a few things that are "odd" about the Norcold; I'm sure there's +/-'s with both huh?
tvman44
Southwest Louisiana
Posted: 07/10/08 06:50am Link  |  Quote  |  Print  |  Notify Moderator
My Dometic does that.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Wherever I happen to park
Posted: 07/10/08 07:08am Link  |  Quote  |  Print  |  Notify Moderator
The cold coils can easily drop below freezing, You open the door, Warm moist air rushes in, and FROST is the instant response.
In the old days you had to DEFROST your home fridge
Today's home friges have heaters in them to defrost between cool down cycles
To put such a heater in an RV would take too much battery power.
JFG
TN
Posted: 07/10/08 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Check door seals using the one dollar bill metod... close door on dollar... it should hold it tightly. If you can pull dollar out easily... bad seals. Unit will defrost fins about every 60 hrs.
Fred
KEBrown
Kansas
Posted: 07/10/08 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys. I certainly hope I don't have bad seals, it's a brand new unit... and I don't have a $1 bill since I just spent a $1000 on the fridge , will pennies work?... I'll giver 'er the $1 test after work.
Harvard
51.37N 114.42W
Posted: 07/10/08 07:35am Link  |  Quote  |  Print  |  Notify Moderator
The amount of ice build is proportional to the outside air humidity and number of door openings.
