JEBar
Willow Springs, NC
as has been noted in a prior post, there are many folks out there who are own and enjoy their Montana campers .... my problem with them is the warranty period and the fact that they use press board in their construction .... Jayco is a far better company and you won't find any press board in either of their Eagle or Designer lines .... of the two, I'd go with a Jayco .... one additional note, their Eagle line is not their entry level unit, it is their mid level line .... the Eagle Light (known until recently as their JayFeather line) is their entry level unit
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
up2nogood
Utah
JEBar wrote: as has been noted in a prior post, there are many folks out there who are own and enjoy their Montana campers .... my problem with them is the warranty period and the fact that they use press board in their construction .... Jayco is a far better company and you won't find any press board in either of their Eagle or Designer lines .... of the two, I'd go with a Jayco .... one additional note, their Eagle line is not their entry level unit, it is their mid level line .... the Eagle Light (known until recently as their JayFeather line) is their entry level unit
Jim
I have heard this mentioned many times, please explain why press board is inferior to whatever else they are using, and I would guess it is plywood ????
snownyet
Western NY
up2nogood wrote: JEBar wrote: as has been noted in a prior post, there are many folks out there who are own and enjoy their Montana campers .... my problem with them is the warranty period and the fact that they use press board in their construction .... Jayco is a far better company and you won't find any press board in either of their Eagle or Designer lines .... of the two, I'd go with a Jayco .... one additional note, their Eagle line is not their entry level unit, it is their mid level line .... the Eagle Light (known until recently as their JayFeather line) is their entry level unit
Jim
Both plywood and osb are held together with glue. The montana may use pressboard but its one continuous piece for the whole floor. No soggy joints to worry about.
2007 Montana Mountaineer 307RKD
2006 Chevrolet 2500 4x4 crew Duramax/allison
Pennie67
Delisle, MS
My parents have a Montana and it has been great. They lived in for 18 months after the storm and have had no issues. I own an Everest which is also a Keystone. We have had for 4 years and lived in it as well for 1 1/2 years. No problems what so ever.
mwebber78
New England
I'll take a continous slab of Structurewood for the decking over having several pieces of plywood. If we are taking exterior grade plywood then that's a hard choice, that's just my take on it.
However, I would NOT allow plywood or OSB to determine which brand I buy. They have both been proven in the construction field and it's a wash in terms of pros/cons.
Anyways my take is to get what you like. If the unit is used then likely the previous person already worked out the several quirks every new RV seems to have!!! If you buy new then Jayco is hard to beat with a 2 year warranty on their units.
The previous poster is correct, the lineup for price/features in the 5th wheel is:
Eagle Superlite
Eagle
Designer
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Camping Pictures
Fire5er
Port Orchard, WA
We sure like our Montana. It's all about what you like. We have not had any problems. Good luck!
richfaa
Ohio
The Jayco Designer and the Montana line are very compairable and as far as quality goes there is no such thing in the RV industry. We have the Montana 3400 but would as well have purchased the Jayco designer. It was a personal choice.
06 Montana 3400. 08 Ford F-350 6.4L
TXcampingfamily
San Antonio, TX
x4
Gin & Mike
2001 Jayco Qwest 265
2001 Ford F350 crewcab 4x4
cdrcos
St. Paul, MN
loydt wrote: Nah, he had it right. The Eagle and the Montana are about the same.
Agree!!
Joe & Barb
2002 F-350,PSD,Crew Cab
2003 HH II LS 32.5 UKTG
*finally retired! *
Albertaguy
Calgary Alberta
x5
