RV.Net Open Roads Forum: Truck Campers: Homemade Mud flaps for the TC Truck
 > Homemade Mud flaps for the TC Truck
Spott
SE Michigan
Posted: 07/10/08 06:10pm Link  |  Print  |  Notify Moderator
The mud flaps I put on the truck when we got it don't offer enough coverage when we're pulling the boat and I didn't like what I found on the market.
So, I made my own, I started with items I already had on hand, steel stock and a never used tailgate protector
I took a piece of square tubing and cut it so when inserted into the Superhitch it sticks out about an inch on each side, I drilled one hole at each end for pins.
Since I didn't want to weld or drill into the superhitch and compromise it's abilities... I used Oak wedges on each end and set them with a 3lb sledge. (Trust me it's not going anywhere)
Each mudflap tube is extended half way into the support tube and pinned with keeper pins. These are as easy to install and remove as my torklift tie-down brackets.
To fill the open end of the tube I inserted a piece of treated wood and curved the end to protect passing legs when the camper is not on the truck.
Me - Kim - Spot
saggys
WI
Posted: 07/10/08 08:30pm Link  |  Print  |  Notify Moderator
Not bad, I may have to do something like that, since I have changed tires with a more aggressive tread pattern they are holding rocks. Is the cross tube on your Superhitch 2.5" tubing? And also is it bolted on the frame mounts?
1999 F350 4WD CC SRW V-10, 4.30 Tow Package, HD Camper Package.
2004 Northstar 850SC with 3 jack Stable Lift.
2006 Triton Frontier 17 with 60hp Merc 4 stroke tiller.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/10/08 09:53pm Link  |  Print  |  Notify Moderator
Looks nice.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
fuelhauler
Southern Oregon
Posted: 07/11/08 01:07pm Link  |  Print  |  Notify Moderator
That ought to protect the boat Bruce. Now you just need some chrome mud flap weights to dress it up abit.
2005 Dodge q/c 4x4 dually six speed pac brake
2006 bigfoot 10.6
2003 Everest 32' 5vr (SOLD)
Spott
SE Michigan
Posted: 07/11/08 06:50pm Link  |  Print  |  Notify Moderator
The Superhitch is 3.4"od, not sure what you're asking in the second part.
Spott
SE Michigan
Posted: 07/11/08 06:52pm Link  |  Print  |  Notify Moderator
I'm going to give it a shot as is on our trip this Sunday up to Oscoda, but I think you are right that it's going to flap too much. We'll see.
capterik
Fort Lauderdale, Florida
Posted: 07/11/08 07:04pm Link  |  Print  |  Notify Moderator
Only one thing missing. You need to add these in chrome.
2003 Kodiak 5500
2006 Bigfoot 25C9.4SB
KVH inmotion Satellite
Stable Lift
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
