shepherds56
Cedar City, Utah
Just ordered a 2008 GMC 2500HD Duramax, Would Bridgestone Revo's be good for towing a fifth wheel? Or any suggestions. Want to get a 2" lift out of tires/wheels.
2008 Duramax/Allison 4x4 short box
Firestone Air Bags
2006 Cherokee 28A Plus
2 Honda EU2000i's
bldrbuck
Boulder, Colorado
Why do you need lift?
fishfinder
Colorado, USA
GM puts good tires on their new trucks. Why do you want to change?
fishfinder, Colorado
'08 Chevy 1/2T 4x4 Ext.Cab 5.3L/3.73 stock P265/70R17 tires
'03 Phoenix Brave Pop-Up TC
rsh_757
Auburn, WA
shepherds56 wrote: Just ordered a 2008 GMC 2500HD Duramax, Would Bridgestone Revo's be good for towing a fifth wheel? Or any suggestions. Want to get a 2" lift out of tires/wheels.
Not possible without lifting the truck. To get that 2" out of tires means no wheel well clearance. For towing a fiver, I would leave it alone unless you really need that clearance. I was LUCKY to be able to pull my fiver level without having to do anything crazy to the trailer after lifting the TV.
2008 Cougar 310SRX 5th Wheel
2005 Dodge Ram 2500 QC 4x4 CTD
2008 Nissan Armada LE
SoCalDesertRider
SanDiego, CA, USA
Yes, Brigstone Revos, Michelin LTX's or BFG AT's in an E load range are all good tire choices.
Don't forget about the wheels. You'll need to change the wheels to fit the wider tires (the taller tires are going to be wider as well).
2" of lift from a change in tires means you need a tire 4" taller than stock. That will have a dramatic affect on your final drive ratio. You'll need to change the axle gears to correct the ratio for the taller tires.
Example-
Say your truck has 3.73 gears and 31" tires on it now and you change to 35" tires.
31 / 35 = 88.5%
3.73 = 88.5% of x (x being the new axle ratio needed to correct for the tire size)
3.73 / .885 = 4.21
You would need to change to 4.10 or 4.30 gears to correct for the 4" larger than stock tires. 4.30's would be preferable to 4.10's.
I'm not convinced that a Chevy 2500 can fit a 35" tire up front without a lift kit. Some trucks can, some can't. '92-97 Ford F350 SRW 4x4's can fit a 35" tire up front with stock suspension, but the newer Fords need taller springs. I don't know how much clearance newer Chevys have up front.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Quote: Want to get a 2" lift out of tires/wheels.
In order to get a 2" lift you would have to go up in tire diameter 4". This might kill your power available to tow and it would surely change your speedometer reading.
Going up 4" in tire diameter will also fill up your wheel wells and reduce the clearance needed for hitting bumps.
Your best bet to get a 2" lift would be to raise the TV with a lift kit.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress - Picture's of our old one
Dave H M
IL
far out
goodcruisin
Greenwood, IN
Revos are one of the best rated AT truck tires. Check out some of the comments at Tire Rack
John (USN Ret) and Debbie
The Paw Pack (Freckles, Stinky & Ranger)
'96 Monaco Windsor 36' DP 8.3L Cummins
Ready Brake w/ Demco Excali-bar
'03 Ford Explorer (Toad)
'04 Honda Insight
'04 Volvo S80 AWD
'74 Dart Swinger Drag Car
14' Boat 9.9 Mercury
dougger222
Maplewood MN
I have the high load range Ravo's on the Excursion and I don't like them. Get a lot more life out of the BFG ATKO's or Terra Graplers. Plus the Ravo's are the most expensive. Won't be buying the Ravo's again.
2000 Excursion limited 4x4 PSD
1999 F350 lariat crew cab 4x4 DRW PSD
1999 F250 xlt 4x4 x-cab PSD
1965 Mustang 289 auto
1969 GTO 400 4sp
1986 GLHS Shelby
1999 Neon R/T
04 PJ 15K dump trailer, 04 H&H 20ft 9K tilt bed
Capt Skup
Southern Maryland/Nantucket
What size tire/rim is your new truck coming equipped with? I still see many new Chevy's with 245 tires and 16" rims. You could probably get a 285 to fit your rim but it would be tight. 265's would be a good fit and in load range "E" you can a much stronger tire over the 245 E's.
Capt Skup
AD-1(AW)USN Ret.
Wonderful Wife, 3 beautiful Daughters
"Never get in a battle of wits with an unarmed man"
2008 F-450 Lariat 4x4
2008 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
