RV.Net Open Roads Forum: Travel Trailers: Suburban 97 ??? pull 07 keystone tt
 > Suburban 97 ??? pull 07 keystone tt
camprs03
algonquin ,il
Posted: 07/11/08 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
We are new to this site... We bought a 07 311bhs keystone sprinter that is parked at a private campground.. We upgraded big time from a pop up ... don't miss those days.
My question is that when i look up the towing weights for the keystone i keep getting different amounts .
I need to know whether the 97 suburban can pull the keystone for a vacation in Sept. of this year .
Any help out there would be appreciated .
Trishie
Life is what we make it ... always has been... always will be !
Camprs 03
07 Keystone Sprinter bhs 311
Ford F250 Diesel Lariat
Me,Wife of 22yrs
2 teenagers (YIKES)
1 Golden Retriver (Buddy)
1 Beagle (Copper)
1 Mutt (Dusty)
LIFE IS GOOD !
NCHornet1
Mt. Airy, NC.
Posted: 07/11/08 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Probably should have checked this out before you bought it. But anyway you need to post the numbers of the TT, we need the dry weight. It should be on a label inside one of the cabinet doors or it will be on the outside, drivers side down low. Then you need to determine the GCWR of your TV. You will exceed this number before the tow rating. The last thing you need to do is weigh your TV. The GCWR is the most your trailer and TV can weigh combined, with all cargo, passengers and a full tank of fuel. Get these numbers and get back to us. If this TT has been sitting for a long time you will need to do some maintenance before you can tow it. Chances are the tires are dry rotted and flat spotted, I am sure the bearings need cleaning and repacking, as well as the brakes need to be inspected and adjusted.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
MFinCA
San Francisco Bay Area, CA
Posted: 07/11/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
I need to know whether the 97 suburban can pull the keystone for a vacation in Sept. of this year.
Forget looking at listed weights for the Keystone. I would suggest towing it over to a scale and weighing it with everything inside that you normally take on a trip. Then you will know exactly how much it weighs
For the 'Burb, there are so many configurations it is hard to determine what it can tow.
I have a '99 3/4 ton Burb with the 7.4L engine and 3.73 gears. The listed towing capacity is 8,000 lbs. I've towed a 7,500 lb. boat with it (the 'Burb was empty except for me). It handles my 6,000 lb fully-laoded (yes, I've weighed it) very well. If my 'Burb had the 4.10 gears, it would tow 10,000 lbs.
A 1/2 ton 'Burb with a 5.7L engine and inadequate rear end gearing wouldn't be up to the task to tow either the boat or my TT.
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
NHguy
NH
Posted: 07/11/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
NCHornet1 wrote:
Probably should have checked this out before you bought it. But anyway you need to post the numbers of the TT, we need the dry weight. No we need the GVWR. Dry weight is some hypothetical number that happens before the trailer is fitted with options.It should be on a label inside one of the cabinet doors or it will be on the outside, drivers side down low. Then you need to determine the GCWR of your TV. You will exceed this number before the tow rating. No, you can't exceed this value.The last thing you need to do is weigh your TV. The GCWR is the most your trailer and TV can weigh combined, with all cargo, passengers and a full tank of fuel. Get these numbers and get back to us. If this TT has been sitting for a long time you will need to do some maintenance before you can tow it. Chances are the tires are dry rotted and flat spotted, I am sure the bearings need cleaning and repacking, as well as the brakes need to be inspected and adjusted.
NCH
Sorry but you need to know the actual weight of the trailer and the actual weight of the tow vehicle as they will be loaded for the trip. As Hornet said you can't exceed the gross combined weight rating GCWR, and you also should watch the TV rear axle rating (RAWR), which is affected by the tongue weight.
My guess is the Sub might not be enough unless it's a Suburban 2500.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
Hornet28BHDS
Parker, PA
Posted: 07/11/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Is the Suburban a 1/2 ton or 3/4 ton?
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
EnglishBulldog
Maryland
Posted: 07/11/08 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I'm interested in following this one...
Have a 2001 Suburban; owners manual is for Tahoe/Suburban; have 4.10 axle, it says we can pull 8k+...but not max total weight.
My Silverado manual tells me max trailer weight and max total weight.
The GF wants to tow our TT (Keystone Outback) @ 6k dry with the Suburban but I'd rather pull it with the Silverado.
5weekendwarriors
iowa
Posted: 07/11/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
My 09 311bhs wieghs 8200 dry. I don't know if your burb is 1/2, or 3/4, but either way it's gonna struggle.
  • 2008 Dodge Ram 3500 Megacab Dually 6.7 CTD 68RFE 6 Speed Auto 3.73's
  • 2009 Keystone Sprinter 311BHS
  • Equalizer 12000# Hitch
  • 2007 Jeep Commander
  • 2004 Lowe Suncruiser 20' Pontoon
  • Gone But Not Forgotten
  • 2006 McKenzie Starwood 30CKS:2001 Jayco Eagle 304BH
5weekendwarriors
iowa
Posted: 07/11/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
NCH
As far as I can tell, the op just wants to know if the burb will pull it. How do you know he don't have a one ton dually as an alternate tv. The "should of checked this out" comment is uncalled for.
camprs03
algonquin ,il
Posted: 07/11/08 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Ya the reply of should have checked this out first really sucks ! The trailer was used 2 times from a friend ... it's very new ...tires and all. The friend towed it out for us with his truck.
Anyway what I have found out on the trailer is that there are 2 weights .. which Im confused on ... shipping weight and carrying capacity.. Shipping is 8140 and capacity is3045 .
The suburban is a 1500 not sure if its a 1/2 ton or more . I will find out . The reason I ask is that it comes with a new motor and engine with warranty for only 4,000 obo . The body is in great shape , tires etc. will have my mechanic check out more in the am.
So I will continue to check out whether it can tow this puppy or not .. Thanks for all the help .
trishie
camprs03
algonquin ,il
Posted: 07/11/08 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I found out more info on the suburban if this helps .GROSS VEHICLE WEIGHT RATING (LBS) 7,300, CURB WEIGHT (LBS) 5,293, GROSS TRAILER WEIGHT BRAKED (LBS) 6,000, GROSS TRAILER WEIGHT UNBRAKED (LBS) 1,000, FRONT AXLE WEIGHT (LBS) 3,600, REAR AXLE WEIGHT (LBS) 4,000, MAX PAYLOAD (LBS) 2,007 AND MAX TONGUE LOAD (LBS) 750
