RV.Net Open Roads Forum: Class A Motorhomes: Unhitching Difficulty after Suspension Mods
 > Unhitching Difficulty after Suspension Mods
ttsr4us
Posted: 07/12/08 04:06am Link  |  Quote  |  Print  |  Notify Moderator
I have a Blue Ox Aladdin and recently had sway bars and trac rods installed. (works great, steady steering, no sway).
Since then though, it has been tougher to unhitch my car. I wonder if this is because the coach suspension is now stiffer. Anyone else experienced this after suspension mods or should I look elsewhere for the cause?
Brian
Brian & Esta plus Sophie the Blue Front "amazing" Amazon Parrot
Dolphin 5342 07 WHrse W22 fitted with Roadmaster F&R sway bars + Davis F BlueOx R Trac Rods, Saturn Vue V6 04 Blue Ox Aladdin and Apollo,
Was
Ex4x4 6.0 PSD 2003, Hensley, Mountaineer 325FKBS
Rvndave
Medina, Ohio
Posted: 07/12/08 04:12am Link  |  Quote  |  Print  |  Notify Moderator
You might try greasing the friction areas, I doubt the mods created this problem.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
itsalleasy
Posted: 07/12/08 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Neither would cause a difference in hitching the car, they help with body roll. The only difference is when the mh is in motion. I would also try grease.
KOG
Winterville GA
Posted: 07/12/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
The track rods (Panhard arms) could contribute to this as they make it more difficult for you to move the MH sideways. But I wouldn't think they'd make enough difference to be a problem. You could always unhook one end of the rear one just to check (while parked of course). In any case it would be worth some little amount of hassle hooking up the toad in exchange for much better road manners with the coach.
Wherever I happen to park
Posted: 07/12/08 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I have a Blue Ox and there is NOTHING you can do to the coach that will make it harder to unhook the car.... You may need a bit of lubrication as per Blue Ox instructions is all
ArchHoagland
Clovis, CA, USA
Posted: 07/12/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
I have found it easier to unhook my toad when sitting on perfctly level flat gound with the toad straight in line with the coach.
When sitting at various angles it can be difficult to remove the pins. Also I spray silicon lube on the pins and all movable parts about every three days when traveling.
I never use grease, ever. Roadmaster towbar parts should only have silicon spray used on them. Don't know what Blue Oxx recommends as far as grease.
I don't think the parts you added have anything to do with the problem you are having. Lubrication is the culprit.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
ttsr4us
Posted: 07/12/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys. Guess the lube ran out at the same time as fitting the suspension mods. Anyhow, well lubed now so shall see. Just about to depart for 3 month trip so just doting i's and crossing t's before leaviving Sunday.
Brian
Posted: 07/12/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
One thing from the Blue Ox FAQ sheet
If you have problems pulling the pins try starting the towed and turn the wheels full right and left.. That may loosen them
How you are parked does make a BIG difference
