RV.Net Open Roads Forum: Tech Issues: A reliable Generator?
 > A reliable Generator?
racefan1965
Redding, Ca.
Posted: 07/12/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
Yahama, Kipor and a lot of folks are bragging about the inverter models that Champion offers. NOTE that Champion (And some of the others too) make both Inverter and "Traditional" generators.
Once again we have info posted that is wrong. Champion does not nor has it ever put out a inverter model genset. Here is a link to all of champions gensets and you can see for yourself. Duro power does put out both types but considering the customer service and quality of the machines I got from them, twice, I wouldn't recommend them to my worst enemy. First genset didn't work right so after a long phone arguement they sent me another one that still "didn't" work right. All at my expense in shipping them back. I've chalked up the experience as a lesson learned and now own a nice $300.00+ boat anchor.lol
Rick, Shirley, Lacy, Misty and 2 dogs(Shasta & Baylee)
1999 Dodge 2500 Quad Cab 4X4
1984 Alpenlite24 5er
1988 Coleman pup
2006 Champion C46540 RV plug ready genset
Beartoo
Perham MN
Posted: 07/13/08 06:04am Link  |  Quote  |  Print  |  Notify Moderator
My Champion runs great and seems to quite compared to others. For 259.00 wasn't a bad investment.
DH - Bear
DW - Marge
Dogs, Rufus and Nelie
01 F 150
1999 Coachman TT
TEXAS
Centerville Tx
Posted: 07/13/08 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Stay away from Kipor. Have a guy in town has one.Less than 10 hours on it and the gen side is burned up. No one in town will touch it.
CJW8
Arizona
Posted: 07/13/08 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
No one in Dallas will touch the Kipor? I find that hard to believe. Find an RV dealer that sells them and I bet you that they will service them. BTW, my Kipor has ran great for three seasons now. The only trouble was my fault and my local RV dealer fixed it, no problem, and I didn't even buy it from him.
2004 F350 PSD FX4 SB CC, Banks Cold Air Intake
18,000 Superglide
2003 37SP Forest River Sierra Toyhauler
2008 Polaris RZR
MrWizard
Van Nuys, Ca
Posted: 07/13/08 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
i would like too see this champion inverter model, i have not seen, do you have a link ?
I love my current champion RV ready 40008 with the electric start, 1 yr old 2000 hrs, leaks a little oil, still runs great, starts every time i hit the key
Connected via Verizon Via LG Dare VX9700
Maximum memory has been reached !
MrWizard
Van Nuys, Ca
Posted: 07/13/08 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Kipors , actually have a decent reputation, but there were some problems with the exhaust pipe touch and melting the plastic and that could be fire hazard on that model, my understanding of the latest model was 'that the problem had been corrected' and was no longer a threat/concern
pnichols
Santa Cruz Mountains
Posted: 07/13/08 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
You didn't mention how much generator power you needed? You mentioned Onans - which can be high watts and you mentioned Honds - which can mean much lower watts.
One of the finest "small" generators ever made was the Honda EX650, which I believe was discontinued in 1998 or 1999 after a run of many years. You can find them used in the price range of $250 to $350 and most likely still running superbly. These are excellent for running lights, small appliances, and charging batteries .... and are almost as quiet (within 1 dB) at full power as the new little inverter Hondas are at idle. Unlike the new Hondas, the EX650 has a steel case. Mine recently sat for 4-5 years and started on the 2nd pull. They'll run at least 7-8 hours on 1/2 gallon of fuel.
* This post was edited 07/14/08 10:04am by pnichols *
Phil, 2005 E450 Itasca 324V Spirit
bill h
el segundo
Posted: 07/13/08 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
pnichols wrote:
One of finest "small" generators ever made was the Honda EX650, which I believe was discontinued in 1998 or 1999 after a run of many years. You can find them used in the price range of $250 to $350 and most likely still running superbly. These are excellent for running lights, small appliances, and charging batteries .... and are almost as quiet (within 1 dB) at full power as the new little inverter Hondas are at idle. Unlike the new Hondas, the EX650 has a steel case. Mine recently sat for 4-5 years and started on the 2nd pull. They'll run at least 7-8 hours on 1/2 gallon of fuel.
Yup. We are solar, but our little EX650 fills in when under trees or clouds. Wish we still had the Little Litton 500W microwave.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
