We are enroute to the FMCA Rally in ST Paul and then on to the Freightliner Chassis Owners Rally in IL.
Yesterday the turn signal switch started operating erratically.
The emergency blinker switch works without a problem. Since it works sometimes, both left and right, it is not a fuse.
Tried spraying from outside with electrical contact cleaner - no effect.
I will try to get access and look for loose connection when we stop at the Rally. If not, try to find a Freightliner dealer or wait until to get to the Rally in IL and ask the Freightliner guys.
In the meantime, hate to be driving without operating turn signals.
Anybody have any additional ideas?
Thanks.
Joe
LandYachtLadySandra
2004 Fleetwood Revolution 40C
2006 Dodge Dakota Club Cab 4X4 carrying two EGO electric scooters
KE5LUU
Chipper, the 7 year old 7 lb chihuahua/? mix, a rescue dog
Sassy, the 1 year old 4 lb. chihuahua/pomeranian, his "sister"
Lord, grant me the senility to not recognize the people I don't like, the good fortune to run into the ones I do, and the eyesight to tell the difference
Anybody know if the turn signal flasher on a freightliner is the same as the one for the emergency blinkers. If so, not the flasher as the emergency blinkers work fine.
Also, anybody know where the flasher is located? I can probably find it by listening for the click when we stop and I can get the turn signal working for a little bit.
Generally they are different flashers. However as to where it's located, Your main Chassis fuse block is usually where they go.. Where that is on a Freightliner I have not a clue
Nothin adds excitment like something that is none of your business John is Near Kenwood TS-2000 housed in a 2005 Damon Intruder 377
I don't have the Freightliner chassis but I, too, was getting erratic signals with my turning signals. Come to find out, the flasher piece was vibrating when traveling over bumps.
Mine is located under the driver area in an outside compartment. I put a rubber-band around the flasher piece and all was fine. I'm not sure if that's what your problem is but it cured mine. My flashers work off the same flasher.
MM
Mr.Mark
2008 Monaco Dynasty, 42ft., 4 slides, 425 hp clean-air Cummins diesel
2007 Honda CR-V EXL, AWD, w/Nav and the M&G braking system
I had the same problem with my turn signals. Try wiggling the 4 way flaser switch. What I found is that when I would adjust the steering whell that I was putting a strain on the 4 way. as soon as I moved the 4 way back into the right position the turn signal worked again.
93 Airstream 35' Dp
5.9 230 uprated to 300 HP
Allison MD 3060
Dutchess and Shadow (fur Bearing Children)
