RV.Net Open Roads Forum: Tech Issues: Chassis Electrical Problem????
 > Chassis Electrical Problem????
AlanC
MD
Posted: 07/12/08 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have an electrical problem that is driving me bonkers
Our 1992 Monaco Dynasty has a two battery (house-4D, Chassis- 8D) system. The chassis battery is charged only by the engine alternator, and is not connected to the inverter/charger or converter.
Our EMS Heart Interface 1200 watt inverter/charger (with remote panel) works properly as a charger when hooked up to shore power and works properly as an inverter (showing 126 volts measured on an analog voltmeter at an outlet) when turned on after disconnecting from shore power and the coach engine is not running. When the coach engine is started though, the inverter will shutdown shortly after being turned on, apparently due to too much DC voltage being input (voltmeter shows 131 AC volts at idle and is pegged at 134 AC volts at cruise rpm). The voltmeter is one of those plug in types that Camping World sells. I understand that accurate voltage readings my be difficult to get from an inverter and in fact, my digital voltmeter showed 109.5 volts with the engine not running and the reading decreased when the engine was started and rpms increased.
At rest, with no shore power, and the engine not running, my 12 volt system shows 12.79 volts. While driving, our 12 volt outlet in the coach shows up to 16.44 volts. Sometimes, after driving for 3-4 hours the voltage will drop to 14.6 and the inverter will function.
I have had the 190 amp alternator checked out and had the brushes and bearings replaced, had the voltage regulator tested, cleaned off all the connections, and also tried another voltage regulator. I have replaced the 12v house battery (4 D) which was just under 4 years old, and tested the diodes in the battery isolator. The engine battery (8D), which is 3 years old, seems to be working fine. I have tried putting the chassis battery on an external charger to top it off before driving, but this has not made a difference. I have also tried two of the small (cigarette lighter plug in type inverters) in our 12v outlet and they seem to shut down due to over voltage as well, but when the engine is turned off, they work fine.
The only thing that I can remember happening that may be somehow connected to this problem is that the main (80 amp) 12 volt circuit breaker that is connected to the house battery failed while the motorhome was plugged in to shore power. During the time the battery was not connected, the converter was still providing 12 volts to the system.
Any suggestions as to what the problem may be would be greatly appreciated.
wilpower
Punta Gorda, Fl
Posted: 07/12/08 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the alternator is putting out too much voltage. I know you said you had it and the regulator checked, BUT I don't think 16+ volts is normal. JMHO
Wil & Cyndi & Einstein (African Gray)
FMCA # F262386
Wherever I happen to park
Posted: 07/12/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
The first thing I'd do is hang a DC volt meter on the house (inverter) batteries and see what is happening on that side of the inverter.
beemerphile1
NE Ohio
Posted: 07/12/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
AlanC wrote:
...While driving, our 12 volt outlet in the coach shows up to 16.44 volts...
Way too much voltage if your meter is correct. I think you need to revisit the alternator output. 14.6 is a high charging rate but possible, 16.4 is bad.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
MELM
GA
Posted: 07/12/08 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
You have a problem between the alternator input to the diode isolator and the voltage at the chassis battery. It may be the diode, or it might be the wire or terminals that connect the isolator to the chassis battery.
The alternator regulator "senses" the chassis battery voltage - you report one reading of 12.79 volts. The regulator will increase the alternator output to bring that voltage to something over 13 volts. But that isn't happening.
But the regulator voltage is increasing, as you report for the house battery voltages.
Check the alternator input to the isolator with the engine running. Then check the isolator outputs to the two batteries - they should be roughly 0.7 volts lower than the input and about equal. The diodes may have passed the resistance checks, but one may be breaking down under load.
If they are correct, then check the voltage at the two batteries. They should be roughly equal (which they weren't in the data you provided). Check the wire terminals and connections - there can be hidden corrosion in the terminal.
Let us know what you find.
Mel & Mary Ann; Mo'Be (More Behave...) and Bella
"If you have an RV, you don't need another hobby." Comment from a friend...
73 Kountry Aire 31.5 ft (semi-retired) TT
90 Champion LaSalle MH 29 ft P30 (89 Chassis)
Visit The Official Blog of the Open Road
YC 1
Yuba City Calif.
Posted: 07/12/08 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Just for a quick test take all the wires on the isolator and stack them together. Make your voltmeter test then. This will eliminate any issues with that.
MELM
GA
Posted: 07/12/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
To be on the cautious side, use the Emergency Start switch when you start the engine if you do as YC 1 suggests. You'll actually be using the wires from the isolator to the two batteries as a "jumper" cable, and there should be a pretty big load on both batteries when starting the diesel. The Emergency Start wiring and relay will carry that current - as designed.
If you have a diode failure in the isolator, doing as YC 1 said is a good way to keep all the voltages under control until you can get a replacement. Just watch the current when starting and disconnect the chassis battery if camping without power hookup.
A couple of links that may be useful:
SurePower Isolator Guide
SurePower Instructions There are testing instructions on the last page.
Mel
AlanC
MD
Posted: 07/12/08 11:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses. I'll do some more checking in the morning.
Now that I think about it, even though the diodes checked out fine, I seem to recall evidence that the isolator got hot at some time.
AlanC
AlanC
MD
Posted: 07/13/08 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks a lot for the isolator suggestion. I checked the voltage with the engine running and got 16.4 VDC at the alternator connection, 15.7 VDC at one of the battery connections, and 13.5 VDC at the other battery connection. I then stacked the wires on the alternator connection and used the emergency start switch to bridge the batteries when I started it. I then got 14.36 VDC at the output and the inverter worked fine. I revved the engine up just to make sure and it did not cut off.
Now for the next question, concerning replacing the isolator. I have a HEHR Powerline 190 amp alternator and the isolator is a HEHR Powerline 190 amp Model 22-31 PL5 190-2. Am I better off trying to track down a HEHR unit to replace it or should I just go to a truck supply place and get any 1-in-2-out, 190 amp unit??
Thanks again for all the suggestions.
AlanC
YC 1
Yuba City Calif.
Posted: 07/13/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Any isolator rated for that current should work fine. Clean the wire terminals with sandpaper and make them shine when you put it back together.
AlanC
