RV.Net Open Roads Forum: Tow Vehicles: Something broken
Search only in Tow Vehicles
 > Something broken
crash32
Ontario, Canada
Posted: 07/13/08 05:17am Link  |  Quote  |  Print  |  Notify Moderator
Sorry I edited:
I'm driving a 2005 Dodge 1500 2 wheel drive or I was anyway.
I was driving done the highway with cruise control on,
when I started loosing speed and the rpm's went up.
I was not pulling a trailer or anything in the box.
The truck wouldn't move!
It wouldn't go in any gear!
Well when It was taken apart the transmission was fine it looked still new.
The then started to take the torque converter apart and said something had brook.
Just wondering what would cause this.
They said pulling trailers had nothing to do with it.
If pulling trailers was the cause you should have transmission problems also.
I don't know anything about this and this forum has been great for input so I thought I would ask.
I'm to get my truck back next week>
Thanks for all the input you have all given.
* This post was edited 07/13/08 12:15pm by crash32 *
Dodge 1500 Hemi 5.7L V8 2 wheel drive, quad cab
heavyputer
Ontario, Canada
Posted: 07/13/08 05:35am Link  |  Quote  |  Print  |  Notify Moderator
Sounds fishy to me. A two wheel drive truck has NO transfer case. JMHO
Heavyputer, 1 DW,
1999 F250 SD SC 4X4 V10 3.73 Husky 16K 4way tilt hitch
Prowler 295R 5er front living room model
Rob_NC
Walnut Cove, NC
Posted: 07/13/08 05:41am Link  |  Quote  |  Print  |  Notify Moderator
You need to get more information from your repair location. As was mentioned, a 4x2 vehicle doesn't have a transfer case. Could they mean rear differential?
surveyorjp
Missouri
Posted: 07/13/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I found that odd as well.
2005 Surveyor SV-291 Tows smooth as silk!
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8 low miles, It ain't pretty, but it's paid for!
carlmel
Heaven (ok Iowa)
Posted: 07/13/08 10:06am Link  |  Quote  |  Print  |  Notify Moderator
If it was the rear end when the truck slowed down the speed odometer should have registered a speed, like your are on ice. Maybe a clue?
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/13/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
If it's an automatic, that sounds like the transmission to me, major torque converter slip or lost the input shaft gear. Usually a rear end will go out with a bang and lock up.
I agree, no 4wd transfer case on a 2wd truck!
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
crash32
Ontario, Canada
Posted: 07/13/08 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Sorry I was wrong.
Its was something with the torque converter.
Like I said I know nothing about trucks.
But what would cause this to go on a 2005 Dodge 1500?
* This post was edited 07/13/08 12:07pm by crash32 *
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/13/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Pulling trailers is hard on the transmission. If you've heated it up from letting it hunt gears, running it in overdrive, or cycling through locking/unlocking the converter, that can cause it to fail eventually.
crash32
Ontario, Canada
Posted: 07/13/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have always pulled with the tow/hauling button on and I don't remember letting it hunt for a gear.
The truck came with the tow package
Could it be just a weak part?
AUWing
Slinger, WI
Posted: 07/13/08 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
It's mechanical - yes it could be a weak part in the torque converter. Odd that there's no mention of burnt trans fluid.
From someplace in SE Wisconsin
2006 Silverado 2500 Ext-cab / reg box / D/A
2006 Jayco Eagle 325BHS
2001 Goldwing, Cyclemate trailer and a tent (to remind me why we have the Jayco)
1999 BMW 1200C (007 bike) too cool to part with
 > Something broken
