RV.Net Open Roads Forum: Fifth-Wheels: solar panel
 > solar panel
w6pea
San Diego, Mexifornia
Posted: 07/13/08 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
ladymc53 wrote:
What kind of money are we talking about for enough panels to keep 4 batteries charged? Will we be able to run our Air Conditioner with 4 batteries and solar panels? We don't want a generator. But don't know the cost. Thanks.
No you will not, you will need an inverter also, at least a 3000w inverter.
And a few more battery's and a lot of panels to keep the battery's charged. Hope you have deep pockets Putting 2 100w panels and a charge controller is a little more than 1600 bucks and that does not include battery's
"Without Trucks & Truck Driver's America Stops!"
Beware of KQ Ranch/CRA Resorts
"Too late to save your shoes,roll up your pant legs!"
"I need more Coffee & Old Bushmills!"
"When all else fails, Ham Radio!"
"Semper Fi"
Beaker
Brevard, NC
Posted: 07/13/08 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Someone will come on here to explain things but running an air conditioner on batteries is not going to happen! It may be 13 amps at 120 volts but on 12 volts, multiply by 10, = 130 amps not counting inverter loss, starting amps, etc.
P(W) = I*V
1440= 12(amps) * 120(volts)
1440= 120(amps) * 12(volts)
Sure wished it worked the way some are thinking.
Trickle charging for batteries is much easier done.
2008 Silverado 2500HD Duramax
1998 23' Jayco lite
luvdoggiez
Sunny Amador county California
Posted: 07/13/08 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Festus2,
I have thought about a very similar setup as far as a portable set up is concerned. THinking we could park the rig under the tree to be in the shade and then put the panel out for the sun light.
My question is, how long a cord do you have? What guage did you use so that you had minimum voltage loss?
Thanks for the help! Happy camping! - Eric-
Click here to see how long until we join you all Full Timing! Count down till full timing for us!
1999 Ford F-250 CC 7.3 PSD W/Superchips in tow safe mode
2006 Cougar 295EFS
Reese 16K Sliding 5th
2 Kipor 2000P generators
Magellan Explorist 210
traveln_circus
Wa.state
Posted: 07/14/08 07:04am Link  |  Quote  |  Print  |  Notify Moderator
P(W) = I*V
When I did the math I forgot to factor in the 12 volt ratio in the conversion. As beaker mentioned it is not possible in a rv. Bite the bullet and get a nice quiet generator (Honda or Yamaha). You will be happy. We can not hear our Honda running inside the coach.
2004 cardinal 33 LX 2000 Ford F350 crew cab PSD.
Smith & Wesson M&P .40 and a Rottweiler.
juzplanekrazy
Huntington Beach Ca.
Posted: 07/14/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
You'll never be able to run a AC unit off of solar and battery's, Unless you have a setup the would run a house. That being said if you want a pretty decent solar setup to keep your 4 battery's up you'll need about 150watts of panels minimum. At a cost of around $1500.00. If you just want to keep them up while in storage you can cut that in half easy.
hypoxia
Arizona
Posted: 07/14/08 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I have a Honda EU3000is which I use. I have two campers, one with 75 watts of solar on the roof, the other one has no solar.
We sure notice the difference when dry camping! With solar we leave fans on all day when we leave with no worry about dead batteries. There are a lot of power benefits with solar. I plan to add it to my other camper, just run the wires thru the refrigerator vent.
For A/C a generator is a must. There is no economic justification for the solar but I sure like it and feel it is worthwhile.
Originally I had the solar on a long wire so I could track the sun but I am lazy so eventually just mounted it flat on the roof.
Jim
My Trailer Rebuild Project
2008 F-350 6.4 Diesel
1990 Collins 24' 5th Wheel
2001 Jayco 311RLS 5th Wheel
ATV Trailer follows the 5er
Festus2
BC Canada
Posted: 07/14/08 09:33am Link  |  Quote  |  Print  |  Notify Moderator
luvdoggiez/Eric
For my portable setup, I have a 25' length of 12 gauge. This is the minimum recommended gauge for this length. I bought 3-wire, heavy duty, outside grade extension cord wire. It is flexible and can be easily coiled. I have a quick disconnect at the solar panel end so I can easily remove the panel from the cord. The other end of the cord is "permanently" fastened to the charge controller. I found that 2 - wire cord is too stiff and is not as easy to coil and store as the 3 wire. I didnt use the green(ground) wire - just the black and white - but it makes no difference.
I am pleased with the tracks inside the basement storage area to hold the solar panel when travelling or leaving the campsite for long periods. It keeps the panel secure and out of the way as the track is mounted on the cross members of the frame (the "joists" of the 5th wheel overhang/bedroom area). So far, I am happy with the way it works. It isnt as convenient as a permanent, roof-mounted one but other than that, I think you can get more effecient use out of it by moving into the sun and at a more optimum angle. You avoid having to drill more holes in the roof --- there are enough there already!
As mentioned, I also built a simple, foldable, "sandwich board" to hold it up while at the campsite. For me, it works well but it may not work for everyone. Price wise --- the panel was $450, the controller $40 and the cord and other supplies about $40-$50. So for around $600, it was well worth it.
2008 Cougar 278RKS
2005 GMC 2500 Duramax
smkettner
Posted: 07/14/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
I have the 15 watt solar Battery Minder and it barely keeps a float charge on the four golf batteries while in storage and all loads disconnected. It gets to about 13.7 volts in summer and 13.4 in winter. In a year it has not that I know of hit 14.2 and switched to float mode. For actual recharging I recommend 100 watts or more.
FormerBiker
Wildomar, Riverside County, CA 25OR624
Posted: 07/14/08 10:41am Link  |  Quote  |  Print  |  Notify Moderator
We are running 2 130w solar panels to charge 3 type 27 batteries. We only run TV/Sat, coffee maker, an occasional fan and a small vacuum with our 1800w inverter. We could run microwave also but choose not to. We also use a 3600w Onan LP generator for occasional A/C and microwave use. The generator is also there to charge batteries if conditions are not good for solar.
All else such as lights, furnace, fantastic fans, water pump, and small TV in the bedroom are run from the 12v battery supply.
Our solar can charge easily at 14+ amps and the batteries are usually fully charged by early afternoon.
We dry camp mostly and rarely run the gen.
DW and I installed the 2 panels ourselves and hooked up the controller, etc. It is not rocket science but get a big enough array to meet your needs. There are worksheets out there to calculate your usage so you can determine what you need.
IMHO getting less than 100w is a waste of money and only good to charging batteries while in storage.
One other thing, if you have "wet" batteries they cannot be neglected. You will be adding distilled water at least once a month. More often if you have more usage.
Lady Vixen and the Rat
2006 Arctic Fox 29-5T (Lady Vixen)
2002 K3500 w/8.1 "It's a gasser!"(The Rat)
retired4fun
Colo
Posted: 07/14/08 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
I bungee our 110w solar panel to a 4 foot aluminum step ladder. That way I can park in the shade and follow the sun. If I need a ladder I rob it from the solar panel. Kill two birds with one stone.
"03" GMC D/A
"04" Snowriver 9/6
"06" Bighorn 3055RL
"06" Polaris 800 EFI
"08" Polaris Ranger RZR
aka chopperbill
 > solar panel
