RV.Net Open Roads Forum: General RVing Issues: Waste Tank Camera
 > Waste Tank Camera
outdoorsman2007
In the Woods - Somewhere!
Posted: 07/13/08 03:45pm Link  |  Print  |  Notify Moderator
I am trying to find a camera that I can snake down the toilet to see the inside of the black tank. I want it to be attached to a hose so I can spray when I see something stuck to the side of the tank.
I believe that if everything in the tank can be sprayed to the bottom of the tank and out the exit hole, it can then be washed out by the contents of the gray tank. I've found that multiple flushes do not completely clean a tank. I always find more paper in the tank no matter how much I flush.
I don't think it's necessary to use everytime we camp, but I do believe that using something like this once in a while would go a long way in keeping the tank clean and everything functioning properly.
Does anyone know of anything like this? Thanks in advance for your help.
SKOOBDO
Sioux Falls, South Dakota (Fulltime)
Posted: 07/13/08 04:00pm Link  |  Print  |  Notify Moderator
Not sure if this is what you are looking for or not?
Snake Camera
2005 F350 LARIAT LE CREWCAB POWERSTROKE TURBO DIESEL DUALLY, OXFORD WHITE, 4X4, TOW COMMAND,C-BETR,16K REESE HITCH, ACCESS TONNEAUCOVER, VORTEX SPRAY IN LINER,
2006 MONTANA 3500RL
MorRyde Suspension and Pin Box. Yamaha EF2400IS
352
Oxfofd, Fl
Posted: 07/13/08 04:09pm Link  |  Print  |  Notify Moderator
yes I made my own.i duct taped my digital camera to my motion sensor light and mounted them at the top of the black water tank.i then hooked them up to a monitor.now if anything is backed up I can clearly see it.if you need a diagram pm me.
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters.
just a good ole southern redneck country boy.our favorite place to go to swim with the manatees
GHMJR
Central New York
Rigid Pipe tools makes a camera I dont know about one that has a hose on it though.
Kajtek1
CA
Posted: 07/13/08 04:29pm Link  |  Print  |  Notify Moderator
I need a sewer pipe inspection and the local plumbers want like $500 minimum.
Bought this one on sale with coupon for like $350 at http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93765
The camera is 3/4" dia and helped me spot the re-bar, while drilling 1" holes in the concrete as well. The few inches tip is so flexible, that goes thru the toilet P-trap.
Why would I need it for my RV tank will remain mystery to me.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
fulltimin
Home is where we Park It.
Posted: 07/13/08 05:15pm Link  |  Print  |  Notify Moderator
2 different, simple, solutions.
1. Use different paper.
2. Put no paper in the black tank.
Problem solved @ no cost.
Dave
If momma ain't happy, ain't nobody happy....
Shower head mod to conserve water.
7th Cav
Someplace
Posted: 07/13/08 07:33pm Link  |  Print  |  Notify Moderator
Would you like tape the event? Share it with friends and family? Never mind.
7th Cav
2004 Damon Intruder 350
Workhorse W22
1997 Ford Explorer Toad
hershey
Albuquerque,(fulltime) NM, USA
Posted: 07/13/08 07:36pm Link  |  Print  |  Notify Moderator
It puts thing into perspective.....some things are much more important to some people than others. A camera in my black tank is pretty far down on my list...heck, I can't even remember to look at my backup camera
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
CSpenceFLY
Macon,Ga
Posted: 07/13/08 08:09pm Link  |  Print  |  Notify Moderator
I'm not sure I understand why you need a black tank that clean.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
Retired Phone Man
Covington, Louisiana
Posted: 07/13/08 08:26pm Link  |  Print  |  Notify Moderator
Now that would be a real "backup camera" or maybe a "rear view" camera depending on how you used it.
2007 Toyota Tundra SR5 Double Cab with 5.7L V8 and Tow Package.
2007 Gulf Stream Ameri-Lite 21MB
Peaches - Lhasa Apso/Mut Mix
 > Waste Tank Camera
