hoffmagl
St. Louis
I am a new owner of a Wildwood travel trailer, model 29bhbs. The water pressure in the shower is fine for about 3 minutes ( long enough to get all soaped up) then is slows to a drip and stays that way. This trailer is hooked up to outside water and the outside pressure is fine. I have checked filters and all are clean. The shower head on off switch is fine. If you wait an hour, it starts up fine, but then does the same thing. Any help would be greatly appreciated!!
Hummer1
Vancouver Wa
Do you have a accumulator in the system? It may be flat and need charged.
Wherever I happen to park
More likely a water pressure regulator.. is there one in the system?
There are 4 types common on RV's today
One is a brass "inline" has a hose coupling on each end (Female/male) may also be made of plastic
The second is like the first but has a color "Grip" on the female end
The 3rd is built into the water inlet on the rig..
The forth is a large device (Compared to the hose) with a bell shaped housing, often with an adjustment screw sticking out of the housing
Pressure gages are optional
That last one works
Dick_B
Palos Heights, IL USA
Is the pressure OK at all of the other faucets? Can you remove the shower head to see if the pressure is the same out of the supply piping?
If the problem still exists I wonder if it could be a problem in the valves. You'll probably get better answers from others.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Bucky Badger
Madison, WI
Also to narrow down the problem check the tub faucet.
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
Nights camping 08 (35)
Rallies/Gatherings
IL
WI
rockhillmanor
On the Road
hoffmagl wrote: I am a new owner of a Wildwood travel trailer, model 29bhbs. The water pressure in the shower is fine for about 3 minutes ( long enough to get all soaped up) then is slows to a drip and stays that way. This trailer is hooked up to outside water and the outside pressure is fine. I have checked filters and all are clean. The shower head on off switch is fine. If you wait an hour, it starts up fine, but then does the same thing. Any help would be greatly appreciated!!
You don't have the pump switch on in your RV do you?
31 ft Four Winds
Chevy Tracker 4x4 BlueOx Aventa LX
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
Nspect
York SC
I'm surprised it works for 3 minutes.
Look inside the cabinet or panel where the main water line enters.
The pex pipe was bent over and crimped in mine where it turned to go through the floor (inside the table/stereo cabinet at the rear) just under the main water connection.
Bruce and Donna
2007 Forest River Wildwood 27RLSS
2003 GMC Sierra 1500 Z71 towing package
Putnam XDR hitch
Equalizer WD with 1k bars
Tekonsha Prodigy brake control
davidj54
South Alabama
If it does fine for three minutes you're taking too long in the shower.
Ok, seriously. My bet would be the water filter. Some of those OEM units are small micron units and exhibit the exact symptom you describe even when new. You can pull it out to test it or you can just relpace it with a 5 or 10 micron mesh.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
