davelinde
Freehold, New Jersey
... can you retract it manually?
In our walk through I was told that mine has no manual backup ...but that "really there's nothing to fail". I've got a ton of literature on the new unit (none that is helpful yet) and I will be looking through it. I may also contact the manufacturer.
But I am looking for info here. My electric slide never failed... but if it did I could still get it in to take it to be fixed. The hydrolic is very nice... fast, smooth, quiet. But I can find plenty that could fail! A hose could burst, a fitting could leak, the pump itself could fail, and even if I could patch a leak that lost too much fluid...
I can only imagine being in the middle of no where with the slides stuck out, trying to figure out where to get parts to repair the hydrolics, then needing to GO there (leaving the RV in...? a rest stop?) This won't fly.
What could I do or what can I change so I won't be exposed to this risk?
Dave Lindemulder
Tammy, Mark & Kirsten
04 Dodge 2500 4x4 SLT QC/SB
HO-CTD/48RE - Graphite: Raptor SS nerfs, Prodigy, Reese 16K Kwik-slide, BD X-Monitor, PML Trans pan, PML Diff cover, Firestone Airbags
09 Heartland Cyclone 3210
tom_kat
way upstate new york/lake george area
if you remove the hydrolic lines to the rams you could push it back in some how but you would have a mess of oil on the ground and probably need some kind of jack and blocks to completely close it and block it so it doesnt slide back out.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
Home Skillet
Pearland Texas
There is a manual over-ride with a crank handle.
My hydraulic slide got stuck in the out position a couple months ago.
I did not have the instructions for mine, so I wasted a lot of time figuring it out.
Turned out that the return solenoid was stuck.
I was able to swap lines and retract the slide.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Festus2
BC Canada
I would be surprised if your slide does not have a manual backup in case of failure of the mechanism and more surprised hearing that your dealer said there is no need for one. In some units, there is a hole in the side of the unit where a long-handled crank is placed to "wind your slide in or out". In mine ( Keystone Cougar), there is a manual crank (operated by a ratchet) underneath the unit. Not sure who invented this system but I pray that my slide never fails to work normally. Unlike yours, mine is electrically operated so all I need to happen is a dead battery and I am hooped. My suggestion to you would be to (a) find where the manual crank is; and, (b) find out how it works.
Should your slide ever fail, phone your dealer and tell him to come fix it!
2008 Cougar 278RKS
2005 GMC 2500 Duramax
F-TROUP
VISALIA, CALIF
The Challenger we had, you could use an eletric cordless drill and 1/4" hex head, insert into the end of the pump and run the hydralics.
thomasinnv
where ever i stop
mine has a manual hand pump just like a hydraulic bottle jack, located next to the motor. just twist a little valve closed and start pumping the handle and all the slides go in.
1999 F-250 Extra Cab SD 4X4 V-10
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
larry barnhart
wenatchee. wa usa
I wonder why most fifths are not electric like in the past. Oil leaks can this be a suprise to anybody.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
PackerBacker
Montreal, Quebec,Canada
F-TROUP wrote: The Challenger we had, you could use an eletric cordless drill and 1/4" hex head, insert into the end of the pump and run the hydralics.
That's how our Wildcat (and I'm guessing most Forest River products) work also.
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec
My Photos
houhjc
at the pump, tx
F-TROUP wrote: The Challenger we had, you could use an eletric cordless drill and 1/4" hex head, insert into the end of the pump and run the hydralics. seems like i tried this a while back just to see if it works, and i couldnt get the slides back in this way.... im sure i did something wrong.
2007 Ram 3500 6.7 DRW 4X4 6speed manual
2003 362bbs bunk house
Holmesb
Virginia
I have a brand new (1 week old!) Wildcat that has the hydraulics as well. Its in the driveway with the slides out so I can check everything out. I was reading the ton of material the dealer gave me because I got the same song and dance when I asked about hydraulic failure. "oh you will need another person to push the slide in, it will take a lot but you can do it." Same thing on the A&E electric awning, "if it breaks when extended there is nothing you can do...."
Ok service guys! Why dont you read the manuals for some of these components you sale!?
A few posts stated to use an allen wrench and electric drill. This will work as long you go in the correct direction
There should also be a "rack and pinion" type mechanism under the slide out, at the end of this rack and pinion there should be a place to hook a crank so you can retract the slide-out. I didn't get one from the dealership but I believe that you can order one from the manufacturer (I vaguely recall reading this in the owners manual..
Hope this helps!? FYI, I haven't even had mine out on its first trip yet!!! Spend a lot of time just sitting in it flipping through catalogs and reading on these forums.
Enjoy!
