popere
Denver
This past weekend the DW and I were camping in the mountains here in CO and during a windy period of the night our Sat reception would cut in and out. I was only able to obtain around 75 - 80% on the signal meter on my initial set up but it worked fine when the wind was not blowing so hard. I checked the Sat itself and I had it staked down and it was very secure. We ended up watching a movie instead of the Sat TV so I know it wasn't my generator.
Any ideas why it was cutting out during high wind periods?
Thanks in Advance
GSF
full-timing in North America
Odds are that a branch swinging in the wind was blocking part of your signal. Or your dish/lnb was being moved by the wind.
George
97 Airstream Land Yacht
01 PT Cruiser Dinghy
Cappy - Pekinese Burglar Alarm
tvman44
Southwest Louisiana
Either the dish was moving ever so slightly or branches were moving in the signal path.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Clay L
Sioux Falls, South Dakota
Winegard has a "wind kit" that will help some. There are some adjustments that may also help some.
You might want to call Winegard, they can help you with both the kit and adjustment information.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
popere
Denver
Thanks guys for the advice.
MELM
GA
Moving to Technology Corner from Tech Issues.
creeper
Richmond Hill, Georgia
Your dish turned slightly on the pole or there was a branch/tree blowing in the path of the sat signal.
Happened to me in texas. Started to rain heavy, branches lowered and waved back and forth. Signal kept coming and going. Moved the dish and problem solved.
Had the dish staked to the ground in 20-40mph wind gusts and never lost a picture.
Wind can not block sat signal.
Blog and projects page
See Profile for more pictures and links
Link Exchange
Wherever I happen to park
I've had 20MPH plus gusting wind and no problem as well
However
If you are "on the edge" even a slight movement will bother it
If there is a tree limb "on the edge" movement of it will bother it
And if there is more than wind (Rain perhaps, or heavy clouds) they too can cause issues
