RV.Net Open Roads Forum: Towing: Open your TT windows for sway control?
Search only in Towing
Open Roads Forum  >  Towing
 > Open your TT windows for sway control?
browns329
New Jersey
Posted: 07/14/08 10:41am Link  |  Quote  |  Print  |  Notify Moderator
A co-worker said to open two windows in your TT (one on each side) to reduce sway. I guess the theory is that if a semi passes you, or wind is blowing against the side, it has a "relief" point to blow through to the other side.
I am a bit skeptical, as I have never heard this before. Does anyone know if this actually helps?
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
mooreadventures
North Carolina
Posted: 07/14/08 10:51am Link  |  Quote  |  Print  |  Notify Moderator
NO! That is about ridiculous! I swear, sometimes I don't see where people come up with stuff like this.
Are you sure your co-worker isn't pulling your leg?
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
downtheroad
Puget Sound
Posted: 07/14/08 10:56am Link  |  Quote  |  Print  |  Notify Moderator
You are wise to be a "bit skeptical." About the only thing this will accomplish is to get the inside of your rig full of road dirt and maybe wind damage your window coverings. If you are getting that much sway, look elsewhere...not at your windows.
This is the same co-worker who will tell you to change you oil every 2000 miles.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
ccattie
Smyrna, DE
Posted: 07/14/08 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I would imagine you'd need some massive windows for this to work.
-c
2006 Jeep Liberty CRD - sold
2005 Ford Expedition NBX
2002 Keystone Cabana
3 Dogs 1 DW
browns329
New Jersey
Posted: 07/14/08 11:09am Link  |  Quote  |  Print  |  Notify Moderator
That's what I thought...thanks!
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 07/14/08 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Sway is diminished or reduced by the use of a properly matched tow vehicle, a good friction or cam type properly set up sway control system, (or a PullRite/Hensley type hitching system) and a trailer that is properly load balanced with correct tire air pressure.
Sway can be felt when a big vehicle passed you, when there are crosswinds, over correcting your steering and road surface irregularities. I wish it were as simple as opening windows or waving a magic wand, but it ain't that easy! You may have to contact a good hitch shop to solve any continuing issues. Good luck!
rolnrolnroln
WA
Posted: 07/14/08 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I would expect that the only results would be multiple broken/missing windows. How do these bizarro ideas get started anyway?
Bearnkat
Fort Worth, Texas
Posted: 07/14/08 11:48am Link  |  Quote  |  Print  |  Notify Moderator
The same way, in a tornado, you're supposed to open all your windows to equalize the pressure. NOT!
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
Chuck and Terry's Pilgrim Adventures
C & T's Photos
North Texas Camping Association
Lone Star Dutch Oven Society
crickeydog
Marietta, Ga.
Posted: 07/14/08 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it really does help! And if you ever find yourself free falling in an elevator, jump up just before the elevator car smashes to the ground and you'll save yourself.
Happy camping!!! See ya'll down the road!!!
AIR FORCE RETIRED "EITHER LEAD,FOLLLOW,OR GET OUT OF MY WAY"!
2006 GMC 3500 SLT CC DRW 4X4 D/A LBZ,PREDATOR & FS2500 OIL FILTER
2004 HR PRESIDENTIAL 30 SCD 5'ER.
CHEROKEE & CHEYENNE, MINI DOXIE'S
LOADED LIKE A FREIGHT TRAIN, FLYIN LIKE A JET PLANE!!
Rollincool
Always Rollin
Posted: 07/14/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - K•HiTS 106.7
