First, we should define "sway", as related to a trailer, and "wind wander" as related to a trailer.
SWAY is a moderate to severe, nearly uncontrollable, whipping back and forth by a trailer. Once you have actually had it, you will know what it is.
Wind wander is what you get when passed by a big truck, or a bus, or when you enter or leave a cut through a hill when a stiff cross wind is blowing. It can be scary.
Sway is caused by an unbalanced load or improperly inflated tires or a poorly built trailer. If a trailer DOES have a sway problem, find the cause and fix it, THEN install a sway control if you think you need it.
The best built, most perfectly balanced trailer in the world, riding on perfect tires, with the best hitch and sway control available, will STILL be subject to wind wander. Even a Class A DP will be subject to wind wander. there is just no avoiding it.
I hope you never have a REAL sway problem. I have, with a poorly built flatbed trailer. It is incredibly frightening!
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
Rather than open the windows, a better idea is to install a drag 'chute on the back of your TT. Then, when the sway begins to get out of hand, deploy the 'chute to stabilize the TT.
Alternatively, add hydraulic flaps along the sides and adjust them as you drive to controll sway.
George
"I was cut out to be rich, but I got sewed up wrong"
2006 Dodge Ram 2500 QC Laramie 4x4 SB CTD auto "Buck"
Flagstaff 26RLS
Hensley Arrow
Prodigy BC
How about using a better sway control hitch instead? Let me ask you this. Do you use a sway control hitch to blow a fresh breeze on you? No. So why would someone use an open window to control trailer sway???
I also heard if you open a rear window and release the pressure, while keeping front windows closed, you will get two more mpg from the difference in pressure.
Surveyor SV-234 >Equalizer> H3
Previously a fiver crew.
In theory it would work in equalizing the pressure variance on opposite sides of the trailer (reduces the suction effect due to passing vehicles). Practically though the SF opening percentage is too small to make a difference.
Some of these people must stay up at night dreaming up these stories....
and to help braking, open a front window and close the back window. This works much better in the winter since the cold air is denser and therefore heavier.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
