RV.Net Open Roads Forum: Tech Issues: Keeping the fresh water fresh
 > Keeping the fresh water fresh
goingnorth
Petersburg, MI
Posted: 07/15/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Also you will never drain all the water out of your tank and lines. Any rotting water left will just be diluted at your next fill up. So I use bleach every time.
08 F350 FX4 CC SB 6.4L
(sold)99.5 F250 sc lb 3.73ls 4x4 100k
28' Jayco talon zx toy hauler 10,000# w/o toy's, tongue wt 1600# Titan Tow Beast wd hitch Dual Cam
22' Renagade 3place snowmobile trailer 2000# w/o toy,s
tommy wilson
southern ca, usa
Posted: 07/15/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
drain and refill every 30 days. works for me.
tommy wilson
1996 kountrystar dp
spartan mountainmaster chassis
tommy wilson
southern ca, usa
Posted: 07/15/08 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
T_Bone
Arizona
Posted: 07/15/08 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I do sanitize twice a year because of the AZ heat and I get water from lakes and streams while boondocking. One cap full of bleach per 1000gal is normal limits. I let this sit over night then drain. This is what the AZDEQ recomends. We run several million gallons of well water thru our commuinty well system each month to supply 400 homes and in over 40yrs have never had one complaint and we pass a strict AZDEQ water test each month.
Then I add 1 cup of vinegar per 60gal and let that sit over night. This can be used to water the plants or lawn. You could also drink if you didn't mind the taste of vinegar, I do so I don't. Vinegar will "sweet'n" any water by removing odors or bad taste, both caused by minerals in the water.
Water can be stored for about 6mths if not exposed to the sun, oxygen, or extreme heat changes, in a NSF container.
T_Bone
02 F350, 4x6, Crew, DRW, PSD, 6spd, 3:73, LWB
32ft RKSS Serria
Please do not trust everything you read on the internet. Use only valid engineering information from well established Companys.
Buy UNION Work UNION
It pays off in the long run
Retired_nuke_ET
Carrollton Va.
Posted: 07/15/08 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Seems awfully weak to me, those caps on bleach bottles are pretty small. Did a little googling and found this, a Cl- disinfection dose chart from the AZDEQ. For 1000 gallons that cap needs to hold 2.56oz
Matthew_B
The boonies near Dallas, Oregon
Posted: 07/15/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
RJsfishin: You've got some good well water then...
Mine tastes and tests fine, but it certainly will grow if left for weeks on end.
jmcnab
Toronto Ontario Canada
Posted: 07/15/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I concur with goingnorth... about 1/4 cup per 100 gals.
02 Yukon Denali XL
08 KZ Spree 324BHS
RJsfishin
Winston Or.
Posted: 07/16/08 05:54am Link  |  Quote  |  Print  |  Notify Moderator
I only meant that all city water originates from a well
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
