RV.Net Open Roads Forum: Tow Vehicles: Silverado mirror extensions ...
Search only in Tow Vehicles
 > Silverado mirror extensions ...
Patch
Northern Illinois
Posted: 07/15/08 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
What are good mirror extensions for a 2008 Silverado 1500 ?? I googled and was disappointed I only got about 12,000 hits. The truck has the standard little mirrors, and would not mind just replaceing them with something well made, or the slide on type if they work. No clue on this end what to do.
I'll bet there's lots of junk out there, and you folks are the experts.
Thanks ...
John Keene
Polk City, FL
Durand, IL
goodcruisin
Greenwood, IN
Posted: 07/15/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I had a set of McKesh mirrors I used on my '99 Silverado. I really liked them. I had the regular mirror plus the convex mirrors on both sides. Once I got them adjusted I could see everything. You can often find them on e-bay. I got rid of mine when I bought my Excursion which had factory extable mirrors.
John (USN Ret) and Debbie
The Paw Pack (Freckles, Stinky & Ranger)
'96 Monaco Windsor 36' DP 8.3L Cummins
Ready Brake w/ Demco Excali-bar
'03 Ford Explorer (Toad)
'04 Honda Insight
'04 Volvo S80 AWD
'74 Dart Swinger Drag Car
14' Boat 9.9 Mercury
Scot
Maryland
Posted: 07/15/08 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Just get the towing mirrors from Chevy, someone last week posted a place to get them, they work great on my 08 silverado...
Scot & Ann
*NEW* 2008 Silverado 3500HD LTZ CC Dually Duramax/Allison
2005 Everest 343L
Hidden Hitch 18k
My Photos
Patch
Northern Illinois
Posted: 07/15/08 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
The 1500 uses dif mirrors than the 2500, etc. I wish I could get those big mirrors ... perfect. I am stuck with the little mirrors and so need the adapters I guess.
John
Patch
Northern Illinois
Posted: 07/15/08 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
These look very good ... big mirror surface ... thanks ...
John
John and Terry
Northern IL
2007 Country Coach Magna
Yukon / Blue Ox towbar
fishfinder
Colorado, USA
Posted: 07/15/08 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Patch,
Extendable towing mirrors are a factory option on the '08 Silverado 1/2T, so you should be able to buy them from Chevy and do the swap.
I almost ordered them on my '08, but decided not since the standard mirrors are already 95" from side-to-side.
fishfinder, Colorado
'08 Chevy 1/2T 4x4 Ext.Cab 5.3L/3.73 stock P265/70R17 tires
'03 Phoenix Brave Pop-Up TC
jmramiller
Dallas
Posted: 07/15/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
If you can find the part number for the OEM camping mirrors the best place I have found to order them is www.partszoneonline.com
Enter the part number in the "Part number search box" and it will take you right to it.
Below are the part numbers for the HD trucks. I thought it was the same for the 1/2 ton but I could be wrong.
If you need mirrors for 07 up - here you go:
Part ID: 19158391 (Manufacturer General Motors)
Camper mirror kit 2007-UP Full-size chevy trucks with DL3 option code.
Price: $386.40
These mirrors are sold as a set. They are also manual extend with turn signal and heated glass. Note that you must have the DL3 option on your truck in order for the mirrors to work properly
15904034 & 15904035 are the part numbers for 99 - 07 models. Total for the two mirrors was $440.00.
Part ID: 15904034 (Manufacturer General Motors)
Description
LH TOWING MIRROR 1999-2007 Full-Size GM truck. It is a manual extend with turn signal and heated glass. This is a direct replacement as long as you have power mirrors.
Price: $220.00
Part ID: 15904035 (Manufacturer General Motors)
Description
RH TOWING MIRROR 1999-2007 Full-Size GM truck. It is a manual extend with turn signal and heated glass. This is a direct replacement as long as you have power mirrors.
Price: $220.00
2006 2500HD CC SB 4X4 Duramax/Allison
Prodigy/16K Reese/265E Tires/Bilstein Shocks
RM Active Suspension/RDS 60gal Toolbox combo
2008 Big Country 3490BHS by Heartland
Patch
Northern Illinois
Posted: 07/16/08 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Thank you very much for your time and effort.
I will take it from here ..
John Keene
Polk City, FL
Durand, IL
Patch
Northern Illinois
Posted: 07/16/08 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Just called my dealer (should have just started with this step I guess), and GM offers the camper mirrors as an option for the 1500 series. Part cost is about $450 to retrofit.
Maybe someone already said this and I just didn't catch it.
These are not same as the 2500, 3500 mirrors, but the same goofy oval shaped mirrors that you can pull out.
Just more info for anyone interested ..
John
jmramiller
Dallas
Posted: 07/16/08 10:10am Link  |  Quote  |  Print  |  Notify Moderator
You may want to check out the mirrors at fenderworld.com. Look just like the OEM mirrors and half the price.
