RV.Net Open Roads Forum: Fifth-Wheels: water pump trouble
 > water pump trouble
GRAVE DIGGER
CHARLESTON/TN
Posted: 07/15/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
I just noticed that the water pump on my fiver when turned on runs all the time. It has good pressure and functions fine it just wont cut off. The fresh water tank has plenty of water so I know that is not it. I would appreciate any help.
javaseuf
Southern Cal
Posted: 07/15/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Either a defective pressure switch on the head of the pump or a defective pump that is allowing inlet and outlet pressures to "bleed".
Have you gone outside to check that water isn't pumping out of your city-water entry?
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
GRAVE DIGGER
CHARLESTON/TN
Posted: 07/16/08 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info the water is not pumping out of the city-water.
sbmowrey
DuBois Pa
Posted: 07/16/08 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Connect a hose to it and see if the pressure from the line stops it from running. If it does you are loosing pressure from a leak and should see water dripping somewhere. Mine was letting the pressure bleed back out of the hose connection itself.
2002 GMC 3500 DRW 4x4 8.1/al
1993 40ft Spinnaker 2 slides/3axles
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 07/16/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a shurflo pump there is an adjustment on the pump to allow you to set the pressure that the pump turns off at. You can try adjusting it. I don't think you have a leak. The adjustment is a screw. Go on shurflo's web site & you may find directions for making the adjustment. If you have the paperwork that came with the pump it is in the literature.
