motor12
austin
i have looked at the pro pressure monitor but have not seen one that shows tire location for a pick up and a 5er. what monitor are you using. i only want one that shows 4 tires on truck and 4 on 5er.thanks
RH913
LONG BEACH NY USA
I got the pressure pro on my rig
You can configure the system to suit
RH913
2004.5 Dodge 3500 LB Quad 4x4 HO CTD Dually- 18K Reese Signature, Brake Smart controler, Pressure Pro tire monitor, Level Air, Rotochok
2005 Holiday Rambler Presidential 36FKT
RALPH
Fire Instructor
Upstate (Albany) NY Area
You want the one that they market as the "Truck and RV" monitor. Don't forget the two spare tires (TV & TT).
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
"If everyone is thinking alike, then somebody isn't thinking!" General George S. Patton
Dennis M M
Geneva, IL
Pressure Pro is great and it can be configured to match any set-up you have. I have mine monitoring 14 tires - 6 on the truck and 8 on the fiver. On top of the warning issue, it give you the ability to scroll through and check all of the pressures from the cab. Have had mine for 4 years and I love it.
Go to Mike McFall's Pressure Pro website. They are Escapees members and will fix you up with a system and provide great customer support.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'05 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro;
Optima Batteries
j2catfish
Newport, NC, U.S.of.A.
All this is good info except it doesn't answer the basic question "...one that shows 4 tires on truck and 4 on fiver..". I do not think pressure pro has such a monitor, their solution is to use the above named "Truck and RV" monitor. To me, it is somewhat confusing to set up and use. I will have to contact Mike McFall again to get some help setting mine up. A simpler display would be a lot of help.
F350 Diesel; Teton 5er;
Native Texan - Transplanted Tar Heel
Retired USMC
Semper Fi !
Dustytuu
Colorado USA
Ditto! We added the truck to ours and just programed it to add the truck.
2008 dodge 5500, diesel, bedsaver, pressure pro tire.
2008 Carri-Lite 36SBQ, 4 slides,dishwasher,washer/dryer,2 fireplaces
D & D
Two Schnauzers, & cat
http://s6.photobucket.com/albums/y250/Dustytuu/
Criminals prefer unarmed victims!
stripit
Clinton Twp, MI
How about looking at the SAF-Tee system that also monitors temperatures along with pressures?
http://www.truckerspartstore.com/category-s/33.htm
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'04 PT Turbo
'Direcway satellite
USA in a Chevrolet
Manahawkin, New Jersey
When you install the sensors on your tires, you will program the monitor. Your monitor will only show 8 tires unless you have a dually pickup, in which case it will show 10 tires. Yes, the picture on the monitor shows a large tow vehicle & a small towed vehicle, but I am smart enough to know that my rig has a big fifth wheel being towed by a pickup truck. It's really not that hard, I just look in the side view mirrors. Sewriously, the Doran system has saved me one tire already & I use it on every trip.
LetsRV
Portland, OR.
USA in a Chev is right (even if he does drive a Chev )
You program the monitor to whatever amount of tires you want to monitor. When you set it up it lets you tell it what sensor is on which tire. Don't get hung up on the diagram on the monitor you can do what ever you want with the sensors.
We are all good at something.....
I just happen to be a good bad example.
Occasionally in error but never in doubt.
edwardt48
lady lake fl
My Pressure Pop only reads 32 tires
