RV.Net Open Roads Forum: Dinghy Towing: jeep adding milage when being towed
Search only in Dinghy Towing
 > jeep adding milage when being towed
richard219
northern indiana
Posted: 07/16/08 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I'm sure that this question has probably been asked and answered a hundred times, so her goes 101. We have a 2005 jeep wrangler (manual)and when we tow it has miles added on. How do we keep this from happining?
Thanks in advance for any help that you can give.
Warfire80
Round Lake Beach, IL
Posted: 07/16/08 09:43am Link  |  Quote  |  Print  |  Notify Moderator
maybe take the front wheels off the ground or the back wheels, not sure which side registers the mileage.
tkcas01
Roaming Fulltimer
Posted: 07/16/08 10:01am Link  |  Quote  |  Print  |  Notify Moderator
You tow it in neutral, or is the 4WD crankcase in neutral? Surprised it accumulates miles. If it is electronic odometer, could find the fuse and remove that when towing, but you would lose station presets.
Working out of my roaming home office... (currently here)
    JFG
    TN
    Posted: 07/16/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
    Where do you have the ignition turned to? It should be in the "OFF" steering wheel unlocked position.
    Fred
    Economical Handyman
    S. California
    Posted: 07/16/08 10:19am Link  |  Quote  |  Print  |  Notify Moderator
    Wow, mine is a 01 with auto and never had the problem.
    I would take it to a Jeep dealer, something has to be wrong.
    DeWayne & Judy
    04 3810 Dutch Star
    ISL 370
    Frank's autoformer
    01 Sahara Jeep-toad
    F 374382
    It is hard to kiss the lips at night, that has chewed your butt all day long!
    deandec
    El Dorado Hills, CA
    Posted: 07/16/08 11:19am Link  |  Quote  |  Print  |  Notify Moderator
    I tow a 1999 and 2005 JGC. Neither has added mileage to the odometer when towing.
    Dean
    95 CC Magna Jeep GC
    (Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
    RicJones
    So. Cal.
    Posted: 07/16/08 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
    I believe if you have everything set according to the manual, you should not be accumulating mileage. Double check that you have the key at first click, transfer case in neutral.
    BarneyS
    S.E. Lower Michigan
    Posted: 07/16/08 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
    Moved to Dinghy Towing forum from Towing.
    hopefulbob
    Wichita, KS USA
    Posted: 07/16/08 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
    Jeeps with electronic odometers should not record mileage when ignition switch is properly positioned for towing.
    Start with the ignition switch in the "locked" position. (key removed, dash indicators, radio, etc are "off", steering wheel locks up when turned)
    Insert key. Turn to the right (clockwise) to the 1st detent position. You can feel this. Steering will become unlocked, dash indicators remain "off", key cannot be removed. If you turn too far to the right, the dash indicators (and other electrical items, including odometer) will come "on". Key remains in ignition switch while towing.
    It is very important that steering wheel is unlocked when towing 4-down. This is accomplished with switch in the 1st detent position, which unlocks steering wheel without energizing electrical circuits. JFG and Ric are correct.
    See your Owners Manual.
    fireman148
    Collierville
    Posted: 07/16/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
    Sounds like it's being towed with the tranny in neutral but not the transfer case. You need to have the transfer case in neutral.
