richard219
northern indiana
I'm sure that this question has probably been asked and answered a hundred times, so her goes 101. We have a 2005 jeep wrangler (manual)and when we tow it has miles added on. How do we keep this from happining?
Thanks in advance for any help that you can give.
Warfire80
Round Lake Beach, IL
maybe take the front wheels off the ground or the back wheels, not sure which side registers the mileage.
tkcas01
Roaming Fulltimer
You tow it in neutral, or is the 4WD crankcase in neutral? Surprised it accumulates miles. If it is electronic odometer, could find the fuse and remove that when towing, but you would lose station presets.
Working out of my roaming home office... (currently here)
JFG
TN
Where do you have the ignition turned to? It should be in the "OFF" steering wheel unlocked position.
Fred
Economical Handyman
S. California
Wow, mine is a 01 with auto and never had the problem.
I would take it to a Jeep dealer, something has to be wrong.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
deandec
El Dorado Hills, CA
I tow a 1999 and 2005 JGC. Neither has added mileage to the odometer when towing.
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
RicJones
So. Cal.
I believe if you have everything set according to the manual, you should not be accumulating mileage. Double check that you have the key at first click, transfer case in neutral.
BarneyS
S.E. Lower Michigan
Moved to Dinghy Towing forum from Towing.
hopefulbob
Wichita, KS USA
Jeeps with electronic odometers should not record mileage when ignition switch is properly positioned for towing.
Start with the ignition switch in the "locked" position. (key removed, dash indicators, radio, etc are "off", steering wheel locks up when turned)
Insert key. Turn to the right (clockwise) to the 1st detent position. You can feel this. Steering will become unlocked, dash indicators remain "off", key cannot be removed. If you turn too far to the right, the dash indicators (and other electrical items, including odometer) will come "on". Key remains in ignition switch while towing.
It is very important that steering wheel is unlocked when towing 4-down. This is accomplished with switch in the 1st detent position, which unlocks steering wheel without energizing electrical circuits. JFG and Ric are correct.
See your Owners Manual.
fireman148
Collierville
Sounds like it's being towed with the tranny in neutral but not the transfer case. You need to have the transfer case in neutral.
