RV.Net Open Roads Forum: How to limit light/heat transmission from skylight in shower
 > How to limit light/heat transmission from skylight in shower
martinandanne
Dallas, Texas
Posted: 07/16/08 09:35am Link  |  Quote  |  Print  |  Notify Moderator
My new Class C has a skylight in the shower. It's an opaque plastic dome type skylight. I don't want to block the light entirely and a cover on the interior is not really a workable option. Does anyone know of any kind of semi-opaque paint that I could apply to the exterior of the dome to limit the light and heat transmission to the interior of the MH?
Thanks
Martin
2008 Four Winds 5000 23A
Rollincool
Always Rollin
Posted: 07/16/08 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Martin,
I took a piece of 1/4" luan plywood and cut out to fit just inside the frame of the sylight. I painted it white to match the skylight frame color. It gets held in place by velcro in four corners.
I leave it up on hot days. Works great! If we want light, simply pull it off with an attached knob I installed in the center of it.
Joe
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Yellowstone 5290 6.0
2007 Chevy HHR Toad 2LT 2.4
1967 Chevy Camaro Pro Street 468 BBC
The Most Fun Radio, on Radio - Tom Kent Radio Network
2Rovers
On The Road
Posted: 07/16/08 10:07am Link  |  Quote  |  Print  |  Notify Moderator
We still like some light to come in our skylight, so we had a piece of screen made to fit and snap in place. It is made of the same material used to make the windshield screen on our motorhome. If it gets extremely hot (which is known to happen in the south ) we put one of those auto windshield reflective screens above the one that is snapped in.
Economical Handyman
S. California
Posted: 07/16/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I painted ours with Kraylon paint that is made for plastic.
DeWayne & Judy
04 3810 Dutch Star
ISL 370
Frank's autoformer
01 Sahara Jeep-toad
F 374382
It is hard to kiss the lips at night, that has chewed your butt all day long!
Hornet28BHDS
Parker, PA
Posted: 07/16/08 10:28am Link  |  Quote  |  Print  |  Notify Moderator
That's a great idea!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
2Rovers
On The Road
Posted: 07/16/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Hornet..... incidentally, we did the same thing with the vent fan over the bathroom.
davidj54
South Alabama
Posted: 07/16/08 10:49am Link  |  Quote  |  Print  |  Notify Moderator
I painted ours too. I had a different agenda though. I wanted to keep ALL the light out. I painted the outside of it with Krylon for plastics paint. I put 2 coats of white on first then 3 coats of black to block out the light then 2 coats of white on top for looks and reflection. Looks good and no light enters the unit. I painted the living area vent cover the same way.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
Bud & Julie dreaming
Thousand Oaks Ca.
Posted: 07/16/08 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Martin
Use white plastic like the type used to cover ceiling lights in offices. It will dull the light and turn it into dual glaze.
Bud
Bud & Julie, Now living our dream!
"Heaven" A place where dreams come true.
MOHO - 2006 3180 DS Coachman Epic
TOAD - 2006 HUMMER H-3
TOAD - 1995 Jeep grand Cheerokee
TOADETT'S - 2 2007 Honda Ruckus scooters
BOAT - 19' 160hp IO bowrider
martinandanne
Dallas, Texas
Posted: 07/16/08 11:04am Link  |  Quote  |  Print  |  Notify Moderator
How long ago did you do this? How is it holding up to being exposed outdoors?
Martin
SSport
Edison, NJ/Stroudsburg, PA
Posted: 07/16/08 11:10am Link  |  Quote  |  Print  |  Notify Moderator
I have the same problem with mine. I am going to be using VHT Niteshades. It's a spray on paint. I have used it to tint many car taillights and so on. It holds up VERY well. Depending on how many coats you put on, determines on how dark it will be.
One coat it will be slightly tinted and up to 5 coats it will be pretty dark, but it is up to you to find your happy medium.
VHT Nite Shades
Pictures
