RV.Net Open Roads Forum: Tech Issues: 50 amp-30 amp
 > 50 amp-30 amp
RoadLizard
SW MISS
Posted: 07/16/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
I just took delivery of a 2008 Jayco Eagle 299RRLS. To my surprise it came with a 50 amp power cord. I has only one a/c unit, no washer, dryer, and no apparent need for the 50 amp hook up, except that there is a place for washer-dryer, if you removed a cabinet. I ask the walk through guy (no electronics tech I'm guessing) and he says sure get an adapter and a 30 amp cord. The book, of course, says no way. I weight 140 and after a long trip that 50 amp cord feels every bit of 150, but I don't want to burn up may new Eagle.
What do you electronics gurus out there say. Thanks
Paul (retired phoneman)
Carolyn (retired teacher)
2 multiclutural dogs (Rosie and Peanut),
All four of us are truly blessed.
2003 F-250 7.3L CC SWB 4x4
USN CVA-64
SSport
Edison, NJ/Stroudsburg, PA
Posted: 07/16/08 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I have a 40 foot Forest River Cherokee which came with 50 amp and my seasonal site was only a 30 amp connection. I used an adapter and have NO problems. I also have a full sized house refrigerator as well.
davidj54
South Alabama
Posted: 07/16/08 11:12am Link  |  Quote  |  Print  |  Notify Moderator
An adapter and 30amp cord will be fine. You'll just trip the feed breaker before you trip the main in the RV. No biggie there. Your individual circuit breakers will protect just like they do on 50 amps.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
smkettner
Posted: 07/16/08 11:23am Link  |  Quote  |  Print  |  Notify Moderator
The breaker will watch for any overload. You just need to watch voltage or get a device that will do it for you.
SWMO
Southwest Missouri
Posted: 07/16/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
A second A/C is optional, but the trailer is setup for all options.
I have an '06 Designer and when we are traveling in cool weather I don't pay for 50 amps, I use my adapter.
They make shorter cords and I would like to have one, but I don't want to sell my youngest grandchild to get one.
The adapters feed both circuits so you don't lose power on any circuits.
2002 Ford F350 Crew, LB, DRW, 7.3L
Jayco Designer 34RLQS
ejforwood
Littleton (Denver) Colorado
Posted: 07/16/08 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Some HOT day when your DW wants to take a shower and your LP is low, and you want to warm up your dinner in the micro, all at the same time, you will appreciate that 50A setup. Plug it into the 50A outlet when ever possible. When 50A is not available, use an adapter.
I think you will find fewer and fewer 30A rigs will be available in the near future.
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
tvman44
Southwest Louisiana
Posted: 07/16/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
You have a 50 amp because the trailer is probably prewired for washer / dryer and 2nd A/C. As long as you don't have any of that you can use and adapter and a 30 amp service. If you turn on too much at one time you will trip the 30 amp breaker on the pedestal. No harm done.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
RoadLizard
SW MISS
Posted: 07/16/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
This is about what I thought but having your back up sure helps. Thanks again.
Wherever I happen to park
Posted: 07/16/08 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
First a question.. Is that cord hard wired or is it one you plug into the side of the rig, then pulg into the park?
If it's hard wired and it's easy enough to do it visit a RV store and get a 50 amp, yes, 50 amp, pigtail. (This is a short cord with plug) replace the long cord with the pig tail and put the long cord in storage. If you wish you may put a FEMALE END on it
if it has a Marineco connector on it (Bit yeller thing you push in and twist) then just put it in storage
At many RV stores (Camping world carries it) you can get a special "Dog bone" connector, it's 30 amp plug on one end and 50 amp Marineco connector on the other, NOT CHEAP (marineco connectors cost a lot of money) but less expensive than just the connector by itself.
Then use 30 amp cords from there.
In fact that's how I'm powering my 50 amp 2-ac class A just now
Save I'm only using one AC, and next to nothing else, not even the televisions
RoadLizard
SW MISS
Posted: 07/16/08 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
It is a plug in.
 > 50 amp-30 amp
