RV.Net Open Roads Forum: Tech Issues: Vent cover replacement
 > Vent cover replacement
wittmeba
Roanoke, Va
Posted: 07/16/08 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I found that 1 of our vent covers over the upper bedroom was broken and the bath is cracked.
I bought 2 replacemtnts - exact replacements for Ventline vents.
The hinge is just a rolled edge and the mating is the same but a little smaller to fit inside. Each end has a small tang to bend outward to keep it from sliding out.
What I cant figure out is how to attach the crank arm. When the vent is in place and hinges in place the arm wont reach the large end of the slot (hole) to be installed.
When the hinges arent mated, and the arm is attached, you cant slide the hinge together.
Anyone know what I should be doing or need to do? I dont want to take the whole vent out as it will break the seal to the roof which we just had re-sealed.
Thanks.
Bruce
Bruce & Carolyn Wittmeier
Vietnam Vet 1968-69
2001 Ford F250 4X4 OffRoad, Auto ESOF, KingCab, ShortBed, Airlift Airbags, DiPricol gauges, SCT-Tuner from DP-Tuners (40/80/120HP), Bilsteins, Reese Slider, Jordan, 2001 30RKFS SunnyBrook w/personal touches
John Wayne
Long Beach, Ca
Posted: 07/16/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Can't remember how I did mine it was a few years ago. Have you tried it from the inside after the top as been installed. You need to remove the screen.
John & Carol
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
KF6HCH
wittmeba
Roanoke, Va
Posted: 07/16/08 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Hi John,
I cant figure out how to remove the screen either. The handle comes off with 1 screw, but the screen seems set in from the outside as it has a lip that keeps it from faliing inside.
Chris Bryant
DeLand, Florida, USA
Posted: 07/16/08 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the trim inside, then the screen, then the operator (crank).
-- Chris Bryant
My RV Service Blog
The RV.net Blog
wittmeba
Roanoke, Va
Posted: 07/16/08 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you John and Chris. Ill give it a shot tomorrow.
Take care,
Bruce
junmy3
Warner Robins GA
Posted: 07/16/08 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I had all kinds of problems trying to replace mine. I called Sunline before they closed and got the instructions. As Chris said you have to to it from the inside of the TT, by removing the trim. I believe there were four screws that I had to take out and then the process was pretty easy.
Jim & Junnie
2005 Sunline Solaris T-2553
Our Web Site
othertonka
Stockton, CA
Posted: 07/16/08 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
I beleive you remove the inside trim and then take the screws out that hold the crank assembly in place and drop the crank assembly down. Now slide the crank assembly end that slides in the vent cover itself into place on the vent cover and then by minipulating the crank handle either up or down, you can get it back to where the screw holes line up and reinstall the screws.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Usnthedog
Lyons, Ks
Posted: 07/17/08 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
It's all done from the inside except sliding the vent cover into place. One problem I encountered was that when the hinges were mated they didn't. The dealer told me to spray with lube so they "break over" but I never got it to work. I finally drove a round tent stake through the vent hinge and opened it up. Worked fine then.
Jeff
othertonka
Stockton, CA
Posted: 07/17/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
For those who might have to replace a Vent cover in the future, here is a web site that shows what the "Hinge" type might look like. Make sure you get the right replacment so the "Hinges" will mate.
Vent cover
wittmeba
Roanoke, Va
Posted: 07/18/08 03:58am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again for more help.
For the benefit of those who might need information, I was able to get a PDF file from their Customer service via their website. By the way, the Hinge diagram was the only way I could determine the brand. Thanks, othertonka.
http://members.cox.net/bruce.wittmeier/technical/VentlineCoverReplacement.pdf
Happy Travels!
* This post was edited 07/18/08 04:17am by wittmeba *
