RV.Net Open Roads Forum: General RVing Issues: Will my battery last untill Friday?
 > Will my battery last untill Friday?
1kennyOG
Port Credit
Posted: 07/16/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Our last trip we had issues with the fridge so today I went and turned on the propane and the fridge on lowest setting. Fridge is empty.
I noticed the battery level reads 1/3.
(1) Will it last till Friday noon?
(2) Will it use up much LPG cooling that empty fridge?
thanks for any help to my dumb questions
the TT and its battery are 1 year old.
65, 68, 02, 03
D & M
Laurel, MD
Posted: 07/16/08 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Charge the battery. Fully discharging it will leadit to premature failure.
Dave & Mary
Isabel (a cuddly little Boston)
Buddy (The Beast) another Boston
2005 Itasca Suncruiser 35A
2003 Jeep Liberty
If it's listed in the Yellow Pages, the government shouldn't be messing around with it.
Kajtek1
CA
Those units take very little propane. When I was camping with trailer averaging 40 days a season, the 5 gallons propane tank could last us 2 seasons for fridge, water heating and cooking.
Battery is another thing. Once they are weak, they can go out without much warning.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
wayne_tw
South Dakota/Georgia
Posted: 07/16/08 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a Dometic, turn off the heater that keeps condensation from forming on the door seals. That eats up lots of juice.
1kennyOG
Port Credit
Posted: 07/16/08 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
5 gallons of propane lasts us 3 long weekends but we're in a cold climate.
1kennyOG
Port Credit
Posted: 07/16/08 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
how is this done?
bldrbuck
Boulder, Colorado
Posted: 07/16/08 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
No your battery will not last until Friday unless you charge it. 33% is considered dead.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
sclark
Minnesota
Posted: 07/16/08 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would charge the battery. Much more likely to run out of electricity before you run out of propane. Good luck.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
smkettner
Posted: 07/16/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Take the fuse out of the propane detector and radio circuit. (along with turning off any condensation control as said above)
The battery is real low but will probably be enough to keep the fridge on. The battery will desperately need to be plugged in to recharge for 24 to 48 hours once utility power is available. Propane use is minimal.
If you are going to be dry camping you better figure out a way to charge the battery. The drive out there will not charge the battery significantly.
1kennyOG
Port Credit
Posted: 07/16/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
no I'm not going to dry camp.
