RV.Net Open Roads Forum: Dinghy Towing: Leaving Highway with toad
Search only in Dinghy Towing
 > Leaving Highway with toad
ROYBUCK
Chester VA
Posted: 07/16/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Class A DP tow a Chevy. Tracker Rodmaster Tow Bar. There is this place in NC that I go to, that has a steep incline when you leave the highway, so I un hook my toad and then re hook back up, what would happen if I did not un hook, when you leave the highway the rear of the MH would go up would this efect the toad to a point wher it would cause damage, it would be the same when I leave and enter the Highway, I travel by myself and it creates a problem for me. I hope I explained this so you could understand what I am talking about. Thanks Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
Rollincool
Always Rollin
Posted: 07/16/08 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Roy,
What degree of an angle are you talking about? Also, what kind of tow bar is it? If it's an all terrain, as long as the angle isn't something drastic, you should be fine.
We use the Blue Ox Aventa LX ALL-Terrain.
I was worried about the same thing with our HHR behind us. DW drove as I watched, NO PROBLEM what so ever. I actually watched closely what it did.
It amazed me.
Best thing is to go easy and slow.
Joe
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Yellowstone 5290 6.0
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
The Most Fun Radio, on Radio - Tom Kent Radio Network
susan-y
North Bend Oregon
Posted: 07/17/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I'm with Joe, get someone to watch or drive so you can have a look see. I've done some interesting roads with my toad attached and if I'm concerned I get someone out to see what's going on. Usually not as bad as I think.
Sue
2005 Chateau Sport w/slide, 24ft, E-450, V-10
Life looks better through a windshield.
robatthelake
Vancouver Island
Posted: 07/17/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
If you exceed the Angle that the Ball Hitch Allows It Will likely Bend the Hitch Or release the Ball! I Have the Stowmaster ,also a Ball Hitch and have exited and entered some pretty abrupt side roads in Mexico, but never have I had to disconnect the Tracker!
Just go really slow and Listen to Your Hitch! You should be OK!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
