RV.Net Open Roads Forum: Tech Issues: Atwood Hot water heater-no hot water
 > Atwood Hot water heater-no hot water
BWhite
Metrowest,Ma
Posted: 07/16/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
No hot water condition all of the sudden . Propane or electricity. Replaced the thermal cutoff . The propane and I am assuming the electrical worked for a couple of minutes then quit . What is the next step ?
Bill and Patti
Gizmo a Black face Tri-color Pembroke Welsh Corgi
Laci a Red and White PWC
06 Fleetwood Revolution LE 40E
05 Hyundai Elantra Toad
Member, Revolution Owners Group,FMCA,CAT RV Engine Owners Club
www.revolutionmotorhome@yahoogroups.com
JFG
TN
Posted: 07/16/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
There is a small automotive type fuse on the circuit board on the heater. Check it.
Fred
nbounder
Arizona mountains
Posted: 07/16/08 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
If it's not the fuse, the next suspect is the control board. Before you shell out $100 for a new one, call Atwood tech (574-264-2131) for troubleshooting help - they are REAL good. If you need a board, get a Dinosaur board from R&G sales, 800-390-3908 - best price.
Joe
BWhite
Metrowest,Ma
Posted: 07/17/08 08:02am Link  |  Quote  |  Print  |  Notify Moderator
I used a temp gun and I see there is hot water in the tank .I am starting to think bad mixing valve?
bacollins
Lawrenceburg, IN
Posted: 07/17/08 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Check the backflow valve on the water heater, mine went bad last year, had only lukewarm water from the taps.
'92 Itasca Sunflyer P series Chevy
'99 Wrangler Toad
'99 Cherokee Toad
'00 Yamaha WR 400
'05 KTM 450 EXC
'92 Honda 750 Nighthawk
Clay L
Sioux Falls, South Dakota
Posted: 07/17/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Also check to see if the outside shower valves are on. If the shower head is off and the valves are on you can get the problem you described.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
BWhite
Metrowest,Ma
Posted: 07/17/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
BINGO ! For the First time I used the sprayer in the wet bay WITHOUT turning the handles off when I was done . I learned something today . THANKS ! Clay I was just on the verge of special ordering a mixing valve.
Clay L
Posted: 07/17/08 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
You are welcome.
I had it happen to me once and someone else helped me with the answer.
