RV.Net Open Roads Forum: Fifth-Wheels: Refrigerator Fan
 > Refrigerator Fan
2oldgypsies
Phoenix, AZ
Posted: 07/17/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Thinking about a Batt. operated fan for our refrigerator. We would like to hear any comments you might have on the subject.
Thank You!
2olggypsies
dennislanier
Georgia
Posted: 07/17/08 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I have personally not seen any need for one in our fridge. I usually keep ours running all the time during camping season (March-November) and clean in out and turn it off otherwise with the door propped open to prevent mildew. Seems like it would take up a lot of valuable space for a questionable benefit.
Bearnkat
Fort Worth, Texas
Are you taking about one for inside or the refrigerator or one for the outside compartment? We're running both.
We purchased both of them at Camping World. The inside one helps keep the air moving around and the outside one comes on and off as needed in hot weather to help the refrigerator run more efficiently especially in hot weather.
In my opinion, both fans help.
Chuck & Terry
2005 Pilgrim 281RB-S
2006 Ford F250 Lariat CC 4x2 PSD
My Lap-Band Journey!
DFW/Central Texas Rally - Fall 2008
Chuck and Terry's Pilgrim Adventures
North Texas Camping Association
Lone Star Dutch Oven Society
j2catfish
Newport, NC, U.S.of.A.
Posted: 07/17/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
For about the same cost, if you are talking about the inside fan, a computer cooling fan can be installed. It moves much more air, you don't have to replace the batteries, and if properly installed can be switch controlled for those times you don't need it.
F350 Diesel; Teton 5er;
Native Texan - Transplanted Tar Heel
Retired USMC
Semper Fi !
tonyandkaren
pennsylvania
Posted: 07/17/08 09:12am Link  |  Quote  |  Print  |  Notify Moderator
We have one in the outside compartment blowing up on the coils. It really makes a difference in hot weather. It's a 12 volt squirrel cage from Radio Shack controlled with a thermostatic fan switch from a heating and air conditioning supply house. Click here for pictures.
http://tinypic.com/1r4zxk77
taxgod4u
Bay Area, CA
Posted: 07/17/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Here is what we did for the inside fan, use a computer fan. Connect the ground wire to an alegator clip, extend the hot so it can be shoved in the hot side of the fridge light socket with the pop in light bulb. Clip the alegator to the internal fins at top of fridge. The fan should have power any time the fridge is turned on. If the fan only runs only when the door is open then the hot is coneected to the wrong side of he bulb. the clip will hold the fan in place for travel.
All things in moderation, except acceleration!
Zip ties, the duct tape of the new milenia!
2001 F250 Powersmoke turbo diesel, 3.73LS
Crew Cab, SRW, SB, 6 inch lift, Single 28 inch semi airhorn underneath! SCMT, A Pillar mounted, Pyro, boost and Trans gauges.
2005 Wildcat 29RLBS, Prodigy, 2 EU2000i's Draw Tite 18K Signature Series, front receiver, on board air, Airlift HD airbags
2003 Ford Explorer XLT 4X4, V8, 5sp AT, 3.73LS
2003 Ford Explorer Eddie Bower 4X4, V8 5sp AT, 3.73LS, Dual semi air horns underneath
2002 XR50, PW50
rob85546
Hot arizona
Posted: 07/17/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hum see you live in phoenix...... Im in AZ as well...Hot outside temps dont help the frig any.. I put one in the top vent to draw the hot air out..... thats where I would put them and i would put 2 of them..easy to do..I was going to put the fan in the back of the frig pointing up, but the fan I got wouldnt fit right in that compartment.
2007 GMC DURAMAX,LBZ,4 by Crew, Allison
Magnaflow Turbo Back Exhaust
Predator Tuner
18by9 Helo's on BFG's
5year old boy
3 year old baby girl
Sea ray boat
Wilderness 5th wheel
SandRail
HD WideGlide
FORD Expediton
honda Eu3000
C Schomer
Buckeye, Az.
Posted: 07/17/08 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I just THOUGHT my frid worked good til I put in the fan! I put a muffin fan in the back and it works so good I wish I would have used two with a switch to run one or both - on the blazin days. Craig
pcm1959
St Augustine, FL
Posted: 07/17/08 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
I did a lot of research on this forum and other rv forums. I have one of the battery operated cube fans inside the fridge to help circulate the air. I installed a flue fan in the top of the refrig exhaust flue compartment - to help in the draft and pull the air out. Most refrigs are not installed exactly as they should be and the natural draft of the flue (space behind the refrig) is disrupted by misinstallation resulting in heat build-up. The fan at the top of the flue helps pull the hot air out. I have read that the fans should NOT blow on the frig coils but simply pull the air out of the flue. You are trying to get the hot air out of the compartment - not cool the coils. These refrigerators generate heat naturally and its part of the process of the absorption refrig. PCM
* This post was edited 07/17/08 10:35pm by pcm1959 *
C Schomer
Buckeye, Az.
Posted: 07/18/08 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
I put mine in the gap between the condenser and absorber coils. I thought that looked like a good place so it can give the airflow a boost at the midpoint. Craig
 > Refrigerator Fan
