Gdlow
Meridian Idaho
For quite sometime, I have been able to plug my MH into a 15 amp plug-in at home...Recently, it has started tripping the breaker in the garage. Nothing else is plugged into the circuit vs at any other (ie water timer system)time. Also the things on in the MH are the typical...the detector for gas...the walkie talkies and the DVR...these total about 5 amps...
Any way to check what is causing the trip...the circuit doesn't trip unless the MH is plugged into it...
Gary And Cathy
'05 Dolphin 5342
Honda Element following us
GS, FMCA 365597
Rallys attended
FMCA Albany, Or.'06
FMCA Redmond, Or.'07
djevans
Tennessee
Put a "clamp on ammeter" on the line from that breaker and assure your self, that you are NOT exceeding 15 amps. Having done that, the breaker still tripping, with a "confirmed " amperage under 15 amps...Replace the breaker...
Battery charger can draw quite a bit of current at times...Your's on?
Confirm that you haven't left any other devices on - electric water heater maybe?
Not a great ammeter, but inexpensive!
If you end up with a "transient" type problem, purchase this one
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
Sully2
Cincinnati
Gdlow wrote: For quite sometime, I have been able to plug my MH into a 15 amp plug-in at home...Recently, it has started tripping the breaker in the garage. Nothing else is plugged into the circuit vs at any other (ie water timer system)time. Also the things on in the MH are the typical...the detector for gas...the walkie talkies and the DVR...these total about 5 amps...
Try swapping out the breaker itself. They can get freaky at times and the heat of the "juice" running thru them can cause them to trip.
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Gdlow
Meridian Idaho
djevans wrote: Put a "clamp on ammeter" on the line from that breaker and assure your self, that you are NOT exceeding 15 amps. Having done that, the breaker still tripping, with a "confirmed " amperage under 15 amps...Replace the breaker...
Thanks for the response...Neighbor just came over and had one of those...found the issue...not the MH after all.thanks for the response
nbounder
Arizona mountains
I bought one of those beautiful Harbor frieght units a few years back, when they were $25 or so. I love it - it has saved my A** more than once. We were going to toss a fridge (the garage fridge) 'cause it seemed to be drawing too much current - making a lot of humming noise. The Ammeter showed it was using 'zactly what it was rated for. made me happy.
nbounder
Arizona mountains
Gdlow - you might want to start at the RR end of the circuit. Shut off all the breakers, and plug it in. I'd guess the house breaker won't trip. Now, at the rig, put on one breaker at a time. Perhaps you can narrow it down this way.
Joe
smkettner
Is it the breaker or a GFI that needs reset?
djevans
Tennessee
Gdlow wrote: djevans wrote: Put a "clamp on ammeter" on the line from that breaker and assure your self, that you are NOT exceeding 15 amps. Having done that, the breaker still tripping, with a "confirmed " amperage under 15 amps...Replace the breaker...
Gdlow . . .
Well now wait a minute...What was the problem?
RV wasn't on the circuit by itself?
Don . . .
Wherever I happen to park
Several possible answers but let me ask
Does it trip a breaker, in a breaker box... Or is it tripping a GFCI (Normally an outlet though GFCI's can be incorporated into breakers)
Many rigs will trip GFCI's, this can be caused by several things including a problem INSIDE THE HOUSE (Or rather with the drop to the house) it can be caused by a converter,, Some converters will trip GFCI's if there is no battery or if the battery is not sufficiently charged. (Please do not ask why)
Further testing is needed.
djevans
Tennessee
wa8yxm wrote: Several possible answers but let me ask
It's already "fixed." He found what was causing the problem. It wasn't the RV. We're just waiting for him to tell us what it was.
