RV.Net Open Roads Forum: newbie, green as grass, scared to death
 > newbie, green as grass, scared to death
Bordercollie
Garden Grove, CA, USA
Posted: 07/18/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
A few more tips: Have a signal flag thing to hang on your steering wheel to remind you to retract the TV antenna if any. Have somebody help you when backing/maneuvering in tight quarters to avoid hitting something, move verry slowly, watch for exaggerated rear end swing, and stop if you hear something. Secure all movable/breakable objects inside before driving, secure microwave tray, if any. so it can't fall out and break. Try to pack things so that they can't rattle and drive you nuts on the road. Test all fire, CO and other alarms.
Test all propane items, water heater, furnace, stove and range top for proper function and no gas leaks. This is a hobby but certain aspects require serious consideration for your safety.
Dakzuki
Carnation, Wa, USA
Posted: 07/18/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
bartandcathy wrote:
Thanks for a fast reply, I have a few ideas about prep maintenance, it is knowing what settings etc. to use that foxes me. I read a great thread about 'dual i beam fords' whatever that means....could this be one of them at 1986?
What about shocks life? 125 Km against 22 yrs? replace them anyway?
Cheers,
Bart
"Dual I beam" is Ford's trademarked name for swing axle suspension which is what it is.
If you look at a Lotus 6 (yes, that old) you will see the same front suspension configuration.
BTW: Michelin says 10 years on their tires (tyres too, I presume) and they do allow some checking (cracks). They have a very good explanation on their web site.
* This post was edited 07/18/08 10:51pm by Dakzuki *
95 Chinook Premier
JesseJ1826
Penetang, Ontario, Canada
Posted: 07/18/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
This is the company that manufactured your motohome
www.glendalerv.com
J J
2001 Four Winds Chateau 31N E450 V10
Stephen C
Illinois
Posted: 07/19/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Bart, when you replace your tires, insist on load range E -- they are heavier duty and will help immensely with sway and lean in corners, when windy, and when passed by trucks. I was really nervous driving my Class C on windy days due to the terrific swaying; then when I had to replace them I went with load range E (I purchased Goodyear tires). The difference was unbelievable. Handling, etc. are all much, much better; my confidence in the vehicle doubled.
Steve
2001 Jayco Eagle 241M Class C
donee
Simi Valley, Ca. 93063
Posted: 07/21/08 09:25am Link  |  Quote  |  Print  |  Notify Moderator
The subject of tire age was mentioned in a previous post.
Id like to mention that when we got our MH in May, I checked the tires after having washed it for the first time.
I found the tires were made the 23 week of 04.
They still had very good tread on them but were starting to weather crack on the sidewalls.
The rig now has a new set of Michelin LT 225/75 X 16's Load range E under it running @ 80 # pressure.
They ran a little more than 1000 bucks.
05 Monaco Esquire 29PBD
05 Silver Dodge Cummins w/3.73 gears 4 spd auto.
