RV.Net Open Roads Forum: Truck Campers: Flipped my fridge and still not working
 > Flipped my fridge and still not working
crazyfritz
Columbia, SC
Posted: 07/17/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
My buddy who is an HVAC and refridge worker for the post office told me that the ammonia and water may have become "stuck" and flipping the fridge over for 24 hrs. or so may free it up and start it working again. So I gave it a try but no success. I am getting heat from the outside components but no cooling on the inside. Maybe it is need of a recharge(freon, ammonia,water)? Any suggestions before I take to someone?
CRAZYFRITZ(29), Christina(26) & Riley(3)
Origin: Columbia, SC
1991 F-350 CREW CAB 4X4
460 GAS (BREATHING GOOD!)
6x12 enclosed hauler (mobile welding)
1989 LANCE LS9000
1957 CHEVY BEL-AIR
greyeyes819
Eastern, PA
Posted: 07/17/08 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Fridge in my friends Class A went too. It ran but just wouldn't get cold. After having to the shop & being told $2k to replace some components or $5K to replace the fridge, they took it back home & simply pulled it out, turned it upside down & banged on the coils a good bit to loosen things up. Seems that did the trick. You tried the turning upside down, did you trying the banging on the coils a bit?
Tami, Daniel
Owen & Ethan
05 F150
07 Sunset Trail 30BH
Reese Dual Cam & Prodigy Brake Control
rhode trip
Rhode Island
Posted: 07/17/08 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, they don't recharge them, you would have to replace the cooling unit. Here's how I did mine:
http://www.rv.net/forum/index.cfm/fuseac......../20341582/gotomsg/20342977.cfm#20342977
2002 Dodge 3500 CTD/DRW/AFE Stage II intake/DPP 95gph fp & big lines/Bilstein HD shocks/Bridgestone Dueler A/T revo
2000 Northern Lite 10-2000cd/ Hellroaring Bic isolator/PD-9160 converter/Trimetric 2020/Lifeline AGM 6v x4=440ah/Onan microlite
Boatycall
Tacoma, WA
Posted: 07/17/08 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Your signature says you have a 1989 LANCE LS9000.
20 years? Time for a new fridge. You actually did pretty good if you got 20 years out of it. "Burping it" as it's called, is only a short term sollution. There's no recharging an RV fridge. They only live, on average, 15 years, you got 20.
Corrosion inside the tubes slowly blocks the lines with sediment. That sediment collects at the bottom of the cooling coils. "Burping it" shakes that sediment up and just spreads it through out the coils, but it quickly settles back down to the bottom again and blocks the ammonia from flowing through the coils.
Sorry my friend, but ya gotta get a new one.... If it makes you feel any better, 20 years really is pretty good.
'01 F350 CC DRW 4x4,4" turbo back exhaust,SCMT,pyro tranny temp& boost gauges,4.10 gears
'03 Arctic Fox 1140,4 Trojan T105s,1.5kw inverter,icemaker
92 YJ 35's,6" lift,ARB lockers,Ford 8.8, 8k winch
Honda 400ex
10k 24' toybox
221, 221, whatever it takes.
JoeChiOhki
Keizer, Oregon
Posted: 07/17/08 09:44am Link  |  Quote  |  Print  |  Notify Moderator
They just don't make 'em like they used to..... (G.E 4.5 Cubic foot, built in 1974, still going).
CB Channel 17 Space Ghost
'1991.5 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
'2004 Bi-Mart 4x8 Cargo Trailer
thomasinnv
where ever i stop
Posted: 07/17/08 09:51am Link  |  Quote  |  Print  |  Notify Moderator
the older units were alot more sensitive to being operated when not level. when running out of level, the fluid will not "flow" back down the coils properly, and begin to pool in the coils, which eventually will start to crystalize. this has the same effect as say cholesterol in your arteries. when there is enough buildup, the fluid will no longer flow properly, and thus no more cooling. unless you are the original owner, you just don't know what that fridge has been put through. if properly setup and maintained, units can last alot longer than 20 years. i had a 68 tc that i gave to some friends, the fridge just gave out last year. thats 39 years.
1999 F-250 Extra Cab SD 4X4 V-10
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
Sportsman Matt
Blackstone, MA
Posted: 07/17/08 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Crazyfritz, I feel soo bad for you taking advise from one of my fellow collegues (I work for the USPS as a Building Equipment Mechanic- HVAC/R), especially when it sounds like he doesn't know his a** from his elbow. NEVER FLIP A REFRIGERATION SYSYEM UPSIDE DOWN. This allows the liquid refrigerant which is considered a solid (hard) to block up the gas (soft) side of the system and block it up worse than the constipated guy on the ExLax commercial.
The only thing I can say is give it time, leave the electric element on, and park the camper in the sun with the refrigerator exterior hatches open. Usually when your system stops working it's due to ammonia building up crystal deposits in the tubing. There is only three fixes for this. One is to rapp on the suspected tube with a rubber mallet and see if the crystalization breaks apart and the ammonia gasses start flowing. Second is to remove the ammonia, replace the section of tubing, and recharge the ammonia. Third is to replace the cooling system entirely, either unbolt and unglue the old cooling system from the back of the fridge or replace the whole fridge.
When I was doing field work for the local RV company I used to only do the first option, for I didn't have the tools in the truck to do the second or third options.
Good Luck
Matt
Life is short, Play harder.
2002 GMC Sierra 1500 Regular Cab Long Bed 4.3L V6 Automatic 2WD
1989 Sunline C-750 Slide In Truck Camper
7'6" Floor, 11'6" OAL
Fishing and Hunting New England and eventually the world
wnjj
Cornelius, Oregon
Posted: 07/17/08 10:29am Link  |  Quote  |  Print  |  Notify Moderator
I had an older (~15 years) fridge stop working once. It fixed itself. It was in a popup trailer and just towing it around on a couple more trips with it turned OFF was enough bumping around that it worked when I tried it again.
I'd try putting it in the back of you truck while you drive to work, errands, etc. It can't hurt.
Matthew_B
The boonies near Dallas, Oregon
Posted: 07/17/08 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Your lowest cost option is to go to RV Mobile and get a rebuilt cooling unit.
It's not possible to do a part charge like a freon system since the system contains water, ammonia, hydrogen and sodium chromate that must be in the right balance. Since they are solids in solution, liquids and gases, they don't leak out at equal rates, they must be completely purged and recharged. This means that the system must be removed and flushed clean. Once you go to this trouble, you might as well get it rebuilt.
Matt
That's true advice for a compressor system, but irrelevant for an absorption system. If the unit has a plug of burned chromate solution from operating out of level, this may dislodge it and put the unit back in operation for a while, possibly years.
Boatycall
Tacoma, WA
Posted: 07/17/08 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Huh? ok, I'm an electrical engineer, NOT an hvac/refer tech, I'll say that right up front, so this isn't my forte', but this isn't household freon-based fridge or a hvac system. Me thinks you're referring to those, as they are quite twitchy when tilted in any way.
I've burped a couple ammonia-based RV fridges in my time, and it HAS brought them back to life for a SHORT period of time.
