RV.Net Open Roads Forum: Truck Campers: Flipped my fridge and still not working
 > Flipped my fridge and still not working
crazyfritz
Columbia, SC
Posted: 07/17/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice,folks. I will pop it out and try "burping it" and definitely let you all know how it works. I will also try a new set of bubble gauges since the ones on the camper are in the same condition as the camper itself. I was using a level of my own and checking them but since the fridge is the most sensitive I will level it only then go to the outside and readdress the bubble situation. For those of you who have been in touch with me before I'm in Maine on Lil' Sebago Lake now and FISHING my ars off!
CRAZYFRITZ(29), Christina(26) & Riley(3)
Origin: Columbia, SC
1991 F-350 CREW CAB 4X4
460 GAS (BREATHING GOOD!)
6x12 enclosed hauler (mobile welding)
1989 LANCE LS9000
1957 CHEVY BEL-AIR
Matthew_B
The boonies near Dallas, Oregon
Posted: 07/17/08 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
The RV fridge isn't that sensitive to level.
Most spec 3° out front to back and 6° side to side.
That's 10" out of level side to side on a 8' truck and 12" out of level front to back on a 20' truck. Basically, if you're comfortable inside, the fridge is OK. It's not OK to leave the fridge running parked on a hill.
The fridge has to be out of level for at least 15 minutes to be a problem. That's why driving isn't an issue, because how often can you go up or down hill without braking or accelerating for 15 minutes steady?
Matthew_B
Posted: 07/17/08 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
One more note on RV fridge reliability:
When they go from old age (rather than burning up out of level), they usually fail from corrosion in the boiler (by the burner), corrosion in the evaporator (the cool coils behind the interior, or metal fatigue at a joint from vibration.
Corrosion is worse when the fridges are cycled on and off - that's when condensation will sit for a while. If you're going to be using the camper again in a few weeks and can leave it on, the fridge will last longer than if it's allowed to sit off for that time.
readytow
Washington
Posted: 07/17/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
I also tried "burping" the fridge, removed it turned it over, listened to it gurgle, banged (gently!!!) on the coils with a rubber hammer, and was able to get 2 more marginal trips out of it. Then replaced it with a new one, never had any problems. So while burping might be a short term fix, since you already have it out to burp it, if it is cost effective for you, I would recommend replacing it.
Boatycall
Tacoma, WA
Posted: 07/17/08 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Matthew_B wrote:
because how often can you...accelerating for 15 minutes steady?
Next time I'm near the Dallas, OR I'll stop by and show ya!
'01 F350 CC DRW 4x4,4" turbo back exhaust,SCMT,pyro tranny temp& boost gauges,4.10 gears
'03 Arctic Fox 1140,4 Trojan T105s,1.5kw inverter,icemaker
92 YJ 35's,6" lift,ARB lockers,Ford 8.8, 8k winch
Honda 400ex
10k 24' toybox
221, 221, whatever it takes.
Matthew_B
Posted: 07/17/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
I said not accelerating for 15 minutes steady
Paoli
Quesnel BC
Posted: 07/17/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I was told by an RV maintenance shop never to start up the fridge when the RV is NOT parked level.
My truck was parked once uphill a steep driveway and the wife started the fridge.
The fridge got messed up real good. Needed to buy a new one. Was 7 years old.
Oh, and btw, these suckers are expensive and could be hassle to install them as well.
We needed to take the camper door (with the frame) right out in order to get the old fridge out and the new one in.
