BirdSongPlace
San Diego County, CA
Quote: But, you still have to get here. Virginia, Tennessee and many other states will still be really hot late in summer....and some well into fall.
That is a good point.
2000 Ford F350
2004 Adventurer
mastercraft1995
Salem, Or
We stay in the camper about 35 nights a year and need help getting rid of moisture. I think the fan will help us do that. Below are 3 options I'm think about. I'm leaning towards the 4000 with the 800 vent cover. That way I have something over the fan that protects the fan from bitter cold blowing snow.
http://www.adventurerv.net/fantastic-vent-model-4000-white-p-180.html
http://www.adventurerv.net/maxxair-fan-mate-fanmate-cover-model-400-p-192.html
http://www.adventurerv.net/maxxair-fan-mate-fanmate-cover-model-800-p-111.html
http://www.adventurerv.net/maxx-air-turbomaxx-all-weather-ventilator-model-3505-therm-p-1675.html
This one would work. I'm just not sure if the fan is protected from the elements.
http://www.adventurerv.net/maxx-fan-maxxair-volt-ventilation-system-white-camper-p-1023.html
I don't think this will work because the vent could become frozen or jammed because of the snow and ice.
1999 F-350, Lariat, PSD, C/C, 4x4, Long Bed.
2004 Malibu VLX.
1994 Lance 880.
xnorp
Spokane Washington
I am with Reddog1 on this I have the Fan-Tastic-Ceiling fan vent with no thermostat and we love it. Also have the MaxxAir/Mate Deluxe would not have the fan without it. Fan-Tastic fan is a great company I have heard nothing but good about them and there customer service is great as has been stated in other posts here. I have the A/C also but with the fan at night just a nice breeze passing from the side windows to the rear with the fan on low is great. Good luck.
xnorp
2000 F-250 SD PS 04 Snowriver 9'6" Rancho 9000X Super Springs Vision 19.5 w/Toyo M608Z
Bumpyroad
Virginia
mastercraft1995 wrote: We stay in the camper about 35 nights a year and need help getting rid of moisture. I think the fan will help us do that. Below are 3 options I'm think about. I'm leaning towards the 4000 with the 800 vent cover. That way I have something over the fan that protects the fan from bitter cold blowing snow.
to get rid of moisture are you talking about shower type or humidity. a fan wont do anything for humidity.
bumpy
Beddows
Abbotsford, Canada
In my old camper I had the same dilema. I installed the A/C where it was wired for it & had a dealer cut a new hole for the fan near a ceiling light where 12v could be obtained. I had the best of both worlds. It was not that expensive to have done.
2004 Chevy 3500 Duramax DRW
2008 Snow River Prestige Signature Edition. (The first of its kind)
mastercraft1995
Salem, Or
Bumpyroad I'm not sure what you mean. My thinking with the fan is we are wet when we return to the camper from skiing all day. So we'll turn the fan on and it should suck the moisture out of the camper because of the air movement. Last year we had a small fan plus open windows and it helped. We just couldn't get enough air movement.
Bumpyroad
Virginia
mastercraft1995 wrote: Bumpyroad I'm not sure what you mean. My thinking with the fan is we are wet when we return to the camper from skiing all day. So we'll turn the fan on and it should suck the moisture out of the camper because of the air movement. Last year we had a small fan plus open windows and it helped. We just couldn't get enough air movement.
OK I assume you are talking about water skiing? or if snow skiing could you even use an AC then? if the area is low humidity your fan would pull moisture off your body, but an AC would lower the humidity if needed. If you are talking about water skiing, why not just use a towel and the AC? Pulling humid air past you wont be very "refreshing" IMHO.
bumpy
mastercraft1995
Salem, Or
I'm talking about snow skiing is the wet North West. We are constantly having to wipe down windows even with the vents and windows cracked with a fan going. I'm just thinking that the fan will keep air flow moving and help suck out the moisture.
Bumpyroad
Virginia
OH, now the answer is obvious. buy a small dehumidifier. will pull out moisture and put in some heat. and if you ever are in hot/humid areas, the AC is what you should fill that hole with, if not, a maxxaire fan.
bumpy
