RV.Net Open Roads Forum: Tech Issues: Water Heater Issue.
 > Water Heater Issue.
alexpinca
Reno, NV
Posted: 07/17/08 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Folks I'm looking for some reassurance that I have nothing to worry about...I have a 32' fiver with the rear kitchen. Every once in while I hear a pretty significant POP. The heater is not in use since its summer, the only thing in the general area is the water heater and the refrigerator (I recently had the recall work done on the refrigerator). I've checked the hot water and it is working fine. Does this warrant a trip to the shop?
Turbo Diesel Dude
Green Mountain, NC
Posted: 07/17/08 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your water heater element firing up. We use electric side while on full hookups as we have a 10 gallon heater and don't use the gas side hardly ever.
charles weidman
jetcare
Mission, TX
Posted: 07/17/08 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Do you mean the furnace is not in use? Is the noise louder outside your RV when standing by the water heater door? Is the water heater operating on propane? Does your water heater have direct spark ignition? You can tell this if you have an igniter that sends a spark to the burner tube when the water heater lights up on propane. Does the water heater ever go into lock-out on start? You would know this if you get an indicator light and you have to turn the water heater switch off and back on to get it to light on propane?
Let us know.
Matt Harris
alexpinca
Reno, NV
Posted: 07/17/08 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Right, the furnace is not in use? I've never been outside when the pop happened. It doesn't happen very often. Yes, the water heater operates on propane. I went to the back of the trailer and removed the cover...it looks very similar to a standard furnace set up, ignitor switch etc. I believe it does have direct spark ignition but I've never actually been looking at the unit when it kicks on. The water heater has been essentially steady on for years. I'm unfamiliar with the lock-out issue. When I've changed parks, I've never had to relight or turn on or off etc.
javaseuf
Southern Cal
Posted: 07/17/08 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the water heater may have a spider web in the flash-tube and then causing the burner to have a small "explosion" because it is starved for propane and when the gas builds up, there is a little too much at the time of ignition.
A good cleaning should cure the issue.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Fulltimers
Anywhere, USA
Posted: 07/17/08 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with javaseuf. Spiders just love propane and will setup housekeeping in the tube where the air/fuel is mixed. Turn off the water heater during the day and note if you hear the pop while it is off. This will narrow it down to the water heater or fridge.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
K5OIT
Conroe, Tx
Posted: 07/19/08 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Dirt dauber nest in the exhaust tube can also cause a "pop" type sound. Easy to see if you open the door and stand back to one side and have someone start the heater. The unit will belch a flame back out of the exhaust tube. I like to never found the nest. It was in the curve where it couldn't be seen. Since it was baked real well, it knocked out real easy.
Good luck, safe travels and happy camping!
02 F250 7.3 Auto CC LB Brakesmart Reese Straightline
98 Sunnybrook 29DBS
