RV.Net Open Roads Forum: 30A Appliance (240v) to 30A TT (120v) Dogbone?
 > 30A Appliance (240v) to 30A TT (120v) Dogbone?
greenrvgreen
open road
Posted: 07/17/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 30-amp 4-prong electric receptical that I would like to hook my 30A TT extension cord into. If I understand this correctly, that 4-prong receptical has 2 hot legs of 120v for a 240v service.
My question: Will a home-made adapter dogbone work for this? What I want to do is connect a 30A TT female end to a 30A appliance male end using 10/3 cord. I would hook the black wire to one of the hot clamps in the appliance plug and simply leave the other unconnected. neutral and ground would connect to their proper wires, of course.
Is there an obvious risk I'm not seeing? or a hidden one? Thanks.
tvman44
Southwest Louisiana
Posted: 07/17/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds good to me, just be sure you don't use the 2nd hot lead by accident.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Mousefart
New Jersey
Posted: 07/17/08 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, as long as you use only ONE hot lead, you will have a full 30a 120v service.
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab, 4.7L HO engine, Factory tow package, Equil-i-zer WD Hitch, Prodigy brake controller.
Yamaha EF2400 Generator.
Wherever I happen to park
Posted: 07/17/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds good to me.. However a sentence of caution
VERIFY EVERYTHING USING A VOLT METER before plugging in your rig
Mis-wired receptacles are... Far too common
smkettner
Posted: 07/17/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the house connector is wired with a full size neutral (#10) and you are good to go with the adapter.
kneal44
EAST CENTRAL TEXAS
Posted: 07/17/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
take the above advise. i did what you are trying to do and blew out the automatic transfer switch. luckly it was a easy fix. but what i did is put one leg to ground or common and the other to the breakers. what the effect was 240 volt to each breaker and BOOOM!!!! breakers triped and the ats fried.
use a voltmeter. if you are not familiar with electrical stuff find a friend there that is.. even a professional electrician.
btw the dogbones are available at many home centers and rv stores.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
Golden_HVAC
Fulltime, CA, USA
Posted: 07/17/08 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Yes this is very easy for those of us that have been fixing electrical things for many years.
Just be sure to test before plugging in the RV for the first time. And each time you plug in the first time at a differant house. You should have 120 volts from the upper left and right flat blades. Then using a 30 to 15 amp adapter and a receptacle tester, you can see if the three LED's turn on correctly. The two yellow lights should come on and the red one stays off.
I always use a 30 to 15 amp adapter with a circuit tester before plugging in, I leave it next to my fresh water hose so it is handy! The one time I plugged into a backwards wired receptacle I did $400 in damage to my built-in inverter/charger.
If you ever upgrade to a 50 amp RV, it is also possible to wire your dryer receptacle adapter to power the 50 amp rv with 120/240 30 amp service that can run both A/C units and much of the stuff in the RV all at once. Limited to about 7,000 watts.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
