donkim
Northcoast, Ohio
Hello All,
Just got done putting up our motorhome garage. Its 32 x 44 x 15 tall. I was looking for ideas on how to best light it. Don
CaBoy
Junction City, OR USA
Don't know if you are planning to do the work yourself or hire it done by a pro, but I have used what the hardware stores here call Shop Lights. They are a 4 foot double tube florescent, 2- 40 watt tubes. They put out a lot of light, even and cover a pretty good area. I use them in my shop and in my other out buildings. Very reasonable to buy & have a good life.
The older I get, the better I used to be.
1997 Prevost by Country Coach
470 HP Series 60 Detroit / 6 SP. Allison
2005 Jeep Grand Cherokee Toad
Same Co-Pilot for 43 years
2 Boston Terrier girls, Scooter & Mia
Jamesrpm
Oregon Coast
With 15 foot ceilings I think I'd get a better florescent , and get the electronic ballasted ones , no waiting for them to warm up to stop flickering. You can call most lighting places and give them the dimensions of your building and intended usage and they will suggest lumen level and fixtures to accomplish it.
___________________________________________
I plan on living forever , so far , so good
OzarkPreacher
S.W.Mo. God's Country
CaBoy wrote: Don't know if you are planning to do the work yourself or hire it done by a pro, but I have used what the hardware stores here call Shop Lights. They are a 4 foot double tube florescent, 2- 40 watt tubes. They put out a lot of light, even and cover a pretty good area. I use them in my shop and in my other out buildings. Very reasonable to buy & have a good life.
My garage is 30' X 40 with 10' sidewalls and I have 12 of these in it. Lights it very well. I wired mine with double 110V outlets that will service two lights each. that way if a light fixture fails I simply unplug it and take it down. Install is reverse. Quick and easy.
Circleearth3
Mayberry
Carefully analyze the placement before you install. If they are placed the way most electricians would install them, at the top, you end up lighting the roof of the motorhome and the sides are in the dark, forget about seeing inside a basement bay. Some where along the sidewalls would probably be better. For a garage this size I'd use florescent, but longer than the 4'. Give it some thought.
JUrban
Delaware
Try a farm supply store and get 2-4 sodium vapor yard lights. Put a piece of tape over the electric eyes, and put them on a switch. If you don't mind the more blue light, the mercury vapor lights are even cheaper.
We have a 94x42' closed machine shed that we park in and it has 2 sodium lights. I use high intensity halogen contractor lights for specific area close work.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
Bruce Brown
Northern NY
Our garage is 32' x 48' w/ a 16' ceiling. I have 80' of fluorescent tube around the outside walls along with another 12' of fluorescent tube over the workbench and in the utility room. I also have (2) 400 watt metal halide lights in the ceiling. It's NICE! and bright.
Here is an interior picture; the lights are at the plywood/metal split.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
cm
Dillon, CO USA
I would also mount some quartz lights, 500 watt. Mount them on a metal outlet box and switch them separately so you can only use them when you need a brighter light.
Place them along the edge of the cieling/wall and that will give you more light for looking into the storage bays. Also put some lights along the lower wall area specifically for looking into the storage bays. Again have them on a separate switch so you can turn them only as needed.
Daveinet
il
donkim wrote: Hello All,
Just got done putting up our motorhome garage. Its 32 x 44 x 15 tall. I was looking for ideas on how to best light it. Don A match and some lighter fluid?? Oh you didn't mean light it in that way.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
flhtci-rider
Montreal, Canada
If you want to save some money on your hydro bill get 2 tube 4' fixtures that use T5 lamps with a good reflector. They put out almost twice the lighting than the old f40 lamps, And if you can't find them at a home depot go to a contracter's supply house.
2006 Scepter
2008 24' Haulmark EDGE
2003 Grand Vitara
My best friend DW
1 fur ball Max (AKA - PITA)
And enough solar power so I never have to start the Genni
