RV.Net Open Roads Forum: Fifth-Wheels: Sidewinder, Superglide or HiJacker
 > Sidewinder, Superglide or HiJacker
Hunter11
Buda, Texas
Posted: 07/18/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
We just bought a new 5th wheel and it came with a Sidewinder hitch. My truck is a LWB and our last 5th wheel had a regular hitch and we never had a problem. I was a little hesitant about the Sidewinder but after our first trip I really like it. Our new trailer is a 36' triple slide and I can back it so much better than our old 32'. It takes a little getting use to when you look back and the trailer is swiveling at the pin box instead of the hitch but you sure can turn it tight. The ride is great as well.
His-2005 Dodge 3500 CTD 4X4 LWB SRW QC Auto 3.73, S&B CAI, Quadzilla X2 XZT Box and Commander, MBRP Exhaust
Hers-2006 Dodge 1500 4dr. Hemi
2007 Crossroads Paradise Pointe 34CK
2 Mini Dachshunds
ALBE
Kelowna B.C.
Posted: 07/18/08 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
18 K Hijacker auto slide,great unit,trouble free,works on all fivers,10,000 miles hauling a 14600 fiver,would never have anything else,the only way to go.,2250$$ can installed.
SuperGewl
Beaverton, Oregon, USA
Posted: 07/19/08 12:18am Link  |  Quote  |  Print  |  Notify Moderator
Pullrite now has an adapter plate that only requires 4 allen screws to hold it on. It allows you to remove the adapter plate in 2 minutes so htat anyone can tow your 5vr.
Another thing to look at is the way the jaws lock on the other hitches. Pullrite is the only one with the jaws completely surronding the pin, not one of htose stupid little bars that slides behind the pin to hold it in place.
2003 Dodge Ram 3500 SB SRW Laramie
TT; 47RE Auto; AMSOIL Head to Tow; Banks Six Gun w/Speed Loader; Fold-A-Cover Tonneau; Pullrite SuperGlide; LINE-X Over the rail; Trailblazer T27FBS 5VR
msredneck84
East Central Mississippi
Posted: 07/19/08 12:27am Link  |  Quote  |  Print  |  Notify Moderator
You need to focus your thoughts for a moment on one key statement in your post "I have been pulling TT for years and this is my first FW".
I was just like you, never pulled anything but bumper pulls all my life (and very proficient doing so) then I bought my first FW. Talk about a different animal towing and backing, jeeeez.
I bought a sidewinder recently and what a relief it handles very similar to a bumper pull not even mentioning all the other benefits already pointed out. Best money I ever spent. Good luck in your decision.
reicharb
Honey Brook, PA
Posted: 07/19/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
You say it pulls similar to a bumper pull. I hope it doesn't sway like a bumper pull.
Big Baldy
Las Vegas, NV
Posted: 07/19/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, no sway. The weight is still over the axle, but instead of the kingpin pivoting in the hitch head the kingpin is locked and the trailer pivots via a turret at the aft end of the pinbox. So, because the pivot point is closer to the bumper the trailer behaves more like a bumper pull when backing. It's great to be able to go 90 degrees if you really need to.
2008 Dodge Ram 3500 Mega Cab 4X4 SRW 6.7L CTD
2006 Weekend Warrior LE3305
2008 Polaris Sportsman 700X2
2007 Honda Rancher TRX420
2007 Polaris Sawtooth 200
2007 Polaris Sportsman 90
Butch50
Roseburg (not for much longer), OR
Posted: 07/20/08 10:19am Link  |  Quote  |  Print  |  Notify Moderator
One thing before adding a Sidewinder is you might want to check with your manufacturer and see if they will still warrant the frame. I know some manufacturers (probably because of lack long term testing) will not back the frame if you install a Sidewinder.
Now before everybody gets excited and says that they have towed theirs for over XXXX miles and has never had a problem, I didn't say not to use it I just stated they might want to check with the manufactrer of their 5er or the frame company who built their frames. They may have legalize in their warranty that states that any modification to the original frame or components voids the frame warranty. If you don't care about it then have at it and enjoy.
This is IMO
Butch
2006 F550 CC 4X4 Lariat PSD/Torqshift Dark Shadow Grey Metalic w/Manning F350 bed
2009 Excel Limited 30TKE (Now have it)
2006 Dodge 3500 Laramie 4X4 QC SB SRW/Cummins 6 speed Jake exhaust brake
Hunter11
Buda, Texas
Posted: 07/20/08 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Butch does make a good point. Ours was installed by Lippert when our frame was built and we do have a full frame warranty from them. I would check with your frame manufacture first about any warranty issues.
Big Baldy
Las Vegas, NV
Posted: 07/20/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
This is IMO
Prudent advice. Since my rig is a 2 (almost 3) year old Weekend Warrior I figured I have nothing (warranty wise) to lose anyway!
reicharb
Honey Brook, PA
Posted: 07/20/08 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
I did check with my Manufacturer (Cedar Creek), they tell me that it will not void there frame (Lippert) warranty.
