ROLINTWO
Full Time -- Canada
Does anyone have this problem and how did you fix it?
Cracking at the screw holes as if from vibration.
we have a 2008 Bighorn 3055RL but other makes have
the same problem.
Any and all ideas.
Thanks
Roy
MBOK
SE Texas
If its an '08 it should be under warrenty, take pictures and contact the OEM.
'06 Truck LWB DRW - '07 37' 5th Wheel
DSteiner51
Wooster, Oh
I watched mine break in two over a ten minute period one real cold morning approx 4yrs ago. Replaced it and no problems since.
D. Steiner
WOJO 1
Sparks, Nevada
Mine are cracking as well on my Cougar. I am afraid to ask the dealer how much it is to replace them.
2002 Duramax 4X4 CC SB
2005 Cougar 296EFS
Reese 16K Slider
2 Hondas in the front storage compartment
TTT Mirrors
tncruiser
collierville,tn
Try drilling a small hole at the end of the crack. It is not a fix but it should keep it from running any farther.
Keith & Patty / TN.
2004 27rl Crossroads Cruiser
2006 Ford F-250 Lariat
The older I get. The better I used to be!
Mountain Mama
N. TX
They aren't terrilby expensive. Someone share this website previously.Tandem skirts Also try doing a search on this forum for them and there should be some other posts about this.
2003 Holiday Rambler Alumascape 34RLT
bpmills
Palmdale,ca
Mine was broken (2009 Bighorn) just the other day when I had it washed, luckily it was able to repaired with crazy glue. I was thinking about checking with a body shop to see if they could back up the screw holes some how so they would be stronger.
Burt
USAFBILL
Alabama
I took mine off and applied "plastic weld" on the under side of each hole. Put them back on and sealed the seam and so far are "holding".
fwnewbie
California
I repaired mine using an epoxy product made for plastic. I took the skirts off and applied it to the back side. I found the stuff at Wal-Mart.
5verfam1
North Ogden, Ut
We had that same problem on our 07 cougar, only on the pass side. was still under wty, so dealer replaced with no ?'s. No problem since, or with the driver side. Good luck
07 Cougar 289BHS,aka "The Man Cave"
07 Dodge 2500 QC Cummins Edge Juice w\attitude,Airbags,
Honda EU3000 Gen
Mazda CX7(wifes ride)
