RV.Net Open Roads Forum: Travel Trailers: Question about TT refers
 > Question about TT refers
MScampers
Vicksburg, MS
Posted: 07/18/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
We are starting to look at the possibility of upgrading our TT. If we find a very good used TT we will buy it. But are tending to steer ourselves toward a new one.
Question: Can we request a new TT without the standard refridgerator? As in leave the space empty. Let us buy our on small fridge/freezer that runs on 110?
We won't be traveling great distances at all. And will NEVER camp where we don't have electricity.
Thanks.
Tarponteaser
Space Coast Florida
Posted: 07/18/08 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
It might be possible to special order a unit without the fridge, but it might be cheaper to buy what is on the lot...some manufacturers are giving $1,000.00 rebate to buy an 08 model. Only thing bad about having a 110 fridge in the trailer is the fact that it will not be able to run while on the road. How long does it take a standard fridge to cool down when plugged in and turned on? I like the idea of being able to turn the fridge on 2 days before we leave so it cools down and the food can be loaded the day before, then it runs on propane while driving to camp.
On our last trip, we went to a resort for 4 days before picking up the camper from storage for a few days of camping....it took a full day for the fridge to cool down sufficiently to unload the cooler. I guarantee next time we camp before the trip to the resort so the fridge can be prechilled.
Regards
Randy
2006 Centennial 3606
2008 F-250 4X4 PSD King Ranch Crew Cab
MScampers
Vicksburg, MS
Posted: 07/18/08 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
The reason hubby wants it with a 110 is the one we bought used the refer didn't work. Had it worked on and it couldn't be fixed. Don't know what is/was wrong with it. So he pulled it out and capped off the line and set in the opening the taller dorm/office fridge. We wanted the even taller fridge with the frost free freezer compartment from Home Depot but it is a few inches too tall to fit in the spot alloted for it in our TT.
They cost so much to replace.
shadows4
Kansas City, Mo
Posted: 07/18/08 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Besides the rebates now being offered, another reason to go with an RV type refer would be resale. I know when we were looking if the fridge had be replaced with a 110 unit we wouldn't even consider the TT.
2000 4X4 Excursion Limited 6.8V10, 4.30, 121,000 miles
Hellwig Rear Sway Bar
Roadmaster Active Suspension
2004 4X4 Expedition 5.4V8, 3.73 208,000 miles
2000 Coachmen 297 RKS
Reese Dual Cam Sway Control
Prodigy Brake Control
JFG
TN
Posted: 07/18/08 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Home type refers also require more amps and are more prone to low voltage conditions... just like your ac low voltage can take out the compressor.
Fred
PopBeavers
San Jose, CA
Posted: 07/18/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
In a similar thread not too long ago I believe that someone pointed out that home style fridges do not tolerate vibration. If that were to be true just make sure you never move the trailer after you install the fridge and all should be fine.
Wayne in San Jose
TV1:2002 Chevy 1500HD 4wd Crew Cab,Valley Odyssey brake ctlr,McKesh mirrors
TV2:2008 GMC 2500HD long bed 4wd Crew Cab,GMC brake ctlr,GMC mirrors
TT:Trailmanor 2720
Honda 2000
Yamaha WR250R,Polaris Sportsman 700 X2,Polaris Scrambler 500
twins89
Walworth, NY
Posted: 07/23/08 05:29am Link  |  Quote  |  Print  |  Notify Moderator
If you are buying new the fridge should las for years. I would never buy a used TT with a dorm fridge, thus you should consider resale value. You will most likely love a new rv that has an rv fridge that works on propane and electric.
Parents who still don't know anything
Twins who are 19, know everything and attend Univ at Buffalo GO BULLS
Clover the Westie who just sleeps
1994 Ford F 250
2002 Montana Mountaineer
Camper G
Pennsylvania
Posted: 07/23/08 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the above, but if you own an older rig (as I do), why would you want to spent 12-1500 dollars to repalce the refridge with a gas/electric refridge, when the rig itself might be worth 3-4K total?
Doesn't make much sense to me. On a new rig, I'd stick with the gas/electric refridge, but if you own an older rig and the refridge dies, I just don't see it being cost-effective to install a gas/electric unit.
My .02, YMMV.
1997 DODGE RAM 4x4, 2500 SERIES, , Reg. cab, 5.9L V8, AT, 4.10 gears. Prodigy Electric Brake Control
1995 BOOMER (Skyline) Model 2223
