Step Child
Apple Valley, Ca.
I was lubin the bearings today and noticed that one of the cross suports for thr fresh tanks had broken a weld, after checking a little more the fresh tanks are loose. You can push up on them about 2" before they touch the bottum of the floor all the bolts are in place, and they don't look like they loosend up. Is it normal to have room above the tanks? The trailer is a WW 32 FSC.
Thanks J.
Racorman
Santa Cruz, California
I've owned 2 WW and on both of them I used commercial steel purchased at an electrial supply warehouse to beef up the system. (I can't remember what it's called) The steel channel hangers that are used by WW and other toyhauler manufacturers are guaranteed to bend. These snap back strait after the water is emptied in the tanks.
AKA..... 56Nomad
2006 Weekend Warrior (LE3305)
1999 Lance Camper (1130)
2005 King Quad 700
2008 King Quad 750
Haul all the toys with a Chevy 1 Ton Duramax/Allison 4x4 -Edge w/Juice and 4" Exhaust
Bigg Al
Hesperia, CA
My tank was held in with three 3/4" X 2" Box tubing supports with a 1/16" wall thickness. The first time I noticed that the tank was sagging, I knew I had to do something about it. I replaced the factory supports with four 1" X 3" box tubing supports with a wall thickness of 1/8 inch. No more sag now.
Tow Vehicle:
2002 Dodge Cummins 2500
Off Road:
2002 Honda XR650
2004 Yamaha YZ450F
2006 Yamaha 660 Grizzly
Race Car:
Pro Street 1968 Chevelle
714ci Nitrous Injected
5 Speed Lenco Transmission
Best E.T. 6.57 seconds at 217 mph
Take me to your Golf Course!!
Devo the dog
Northern California
Racorman wrote: I've owned 2 WW and on both of them I used commercial steel purchased at an electrial supply warehouse to beef up the system. (I can't remember what it's called)...
Unistrut.
Racorman
Devo the dog wrote: Racorman wrote: I've owned 2 WW and on both of them I used commercial steel purchased at an electrial supply warehouse to beef up the system. (I can't remember what it's called)...
Unistrut.
Thanks..... It is interesting metal that has memory. I straightened the existing bars and then placed Unistrut under them. Now when the water tanks are full, they bow downward to carry the load, but as the water is used, they go back to being strait and level. Great improvement.
mapguy
Puget Sound
Racorman wrote: Devo the dog wrote: Racorman wrote: I've owned 2 WW and on both of them I used commercial steel purchased at an electrial supply warehouse to beef up the system. (I can't remember what it's called)...
Unistrut.
Unistrut is one brand name for this u -shaped channel material.
Great multi-purpose steel strut -it is available at Home Depot and Lowes in the electrical section usually near or on the conduit rack. They also carry joining plates, angles and hanging clamps to fit the stuff, too.
Map Guy
Racorman
Also, what is great is that all the holes are ready for the hangers. No drilling required..... just cut them to the length of your existing bars and then install. Easy mod
Step Child
Apple Valley, Ca.
Thanks for the tips for the metal straps/mounts, but what I noticed is when the tanks are empty they move around alot. I can push them up about 2", all the mounts look ok. Should their be that much room above them? Should they be tight against the floor of the trailer?
Thanks J.
DuneMe
Elk Grove, CA
I'll have to check mine again but, I remember being under the trailer at one time and noticing the same thing. . . the tanks seemed to move when empty. I wouldn't worry about it too much as long as you don't see the sag being mentioned.
Unistrut is great stuff. It is getting more and more expensive with rising steel prices though. . . Ouch!
2005 GMC Sierra 4X4
Duramax Diesel - Edge w/ Attitude / 4" exhaust / Cold Air Intake
45-gallon TransferFlow Tank
4" Lift
Air Bags
Weekend Warrior LE3905 Toy Hauler
TomPro Mini-Rail - Turbo Hayabusa
Raptor 700's for the Wife and I
250EX - Daughter's
PsnRebel
On My Banshee, In the Dunes !! In SoCal
I'd be careful about adding too much support after the mfg's. The water tank needs room to expand while filling. Yes, it should have an air vent, but they still tend to expand somewhat.
My buddy cracked the floor in his trailer, put a nice size hole in it, because the tank expanded upwards against the floor, not down where there was room for it to expand.
