RV.Net Open Roads Forum: Dinghy Towing: 4 down towing
Search only in Dinghy Towing
 > 4 down towing
ArchHoagland
Clovis, CA, USA
Posted: 07/18/08 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Roadmaster Sterling. Im here to tell you it works fine on level ground.
You are welcome to unhitch it for me on unlevel ground, because it's a bear then.
I almost always unhitch at the checkin place if it's staight and level.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
JohnnyT
Goshen New York
Posted: 07/18/08 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from class A forum
rockhillmanor
On the Road
Posted: 07/18/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Sully2 wrote:
The Texan wrote:
We use the Roadmaster AT, which can be easily hooked or unhooked on any out of level terrain condition. Previously had a regular(non AT system) and as was said earlier, you had to be perfectly level to hook or unhook. We are very satisfied with the Roadmaster products.
Sorry..cant go with the "have to be level stuff" at all!
Uphill or down hill..dont matter.
1) You set the brake on the toad..so it cant more AT ALL.
2) Your "navigator" or "better half" or..?...gets into the coach..foot on the brake pedal and put the coach into GEAR
That takes all of the "pinch and bind" out of the pins in the arms....you pull the pins and tnen stow the arms in their stored position ( Adventa model)
Unhook the electrical and give the "driver" the sign to put the coach back into park
thats all their is to it
Can I borrow your 'better half'?
Pinch and bind on the pins comes standard when you travel solo.
Real good tip to eliminate it though.
BTW: I just got my toad and it's REAL good to hear that 'everyone' has the same problem and it's not just something I am doing wrong.
* This post was edited 07/18/08 05:04pm by rockhillmanor *
31 ft Four Winds
Chevy Tracker 4x4 BlueOx Aventa LX
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
bacollins
Lawrenceburg, IN
Posted: 07/18/08 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
MAJESTYPOINTERS wrote:
I am shure you will get a lot of "brand" name advice on here.
Here is how I picked Mine....
I used this simple saying "Keep it simple stupid"....
Now I am not saying anyone is dumb but I feel the fewer moving parts....the fewer places to brake or fail...JMO
That how I aproched my hitch purchase.
I'm on the same page. Went with a Blue Ox Ambassador A-frame towbar in '00, still doing a good job.
'92 Itasca Sunflyer P series Chevy
'99 Wrangler Toad
'99 Cherokee Toad
'00 Yamaha WR 400
'05 KTM 450 EXC
'92 Honda 750 Nighthawk
BaldyD1
Central Florida area
Posted: 07/18/08 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
The ReadyBrute Plus (aluminum tow bar w/integrated braking system rated at 8K lbs) costs about same or less than the tow bar alone from other manufacturers.
Less cost, lighter weight, high weight rating, and braking system - what more can be asked about a tow bar?
NOTE: Spell check not working. Please forgive any spelling errors.
Edited AGAIN by BaldyD1 {7-19-08} to correct rating of the ReadyBrute Plus tow bar in first sentence. Hope this time it's correct!
* This post was edited 07/19/08 08:21pm by BaldyD1 *
Speedy, Jackie & Dusty {Shih-Tzu/Maltese}
2006 Kountry Star KSDP 3912
2005 Saturn Vue (dinghy)
chastho
arkansas
Posted: 07/18/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
When I first got my Blue Ox I had a problem at times with the pins being in a bind. I called them and was told to just turn font wheels on the toad and it will free up the pins. Works everytime.
Sully2
Cincinnati
Posted: 07/18/08 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
You have to foot the bill for her just like I do....
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
chastho
arkansas
Posted: 07/18/08 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't like the roadmaster because of the cross bar on the front of the toad. I think they have made it removable now but it is still extra work and extra time to hook and unhook.
JaBob
Roswell, Georgia
Posted: 07/19/08 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
They all work! It's like Ford vs Chevy. Just make sure you have edequate capacity with safey chains.
Bob
427435
Rochester, Mn
Posted: 07/19/08 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for the Ready Brute (tow bar only) or the Ready Brake (tow bar and brake combined). Rugged, reasonable weight (made from aluminum but stout), and easy to unhook even on uneven ground. Don't even need the DW to move anything.
And did I mention less expensive than all the "name" brands!!
Check them out. I've dragged a 5,000 lb Explorer all over the mountains of Colorado and to Alaska and back (almost---still 750 miles from home) and I'm very pleased with it.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
 > 4 down towing
